I'm running auconfig to define a test system in the RCS server. I exported the xml file from the SCS console which shows SCSVersion 9.1.0.90 and when I run auconfig on the workstation to import the configuration, I get the following errors:
2014-07-08 15:06:12:(ERROR) : ACU.dll, Category: LoadXMLFromFile: The value of the SCSVersion tag in the profile is not applicable to this Intel(R) SCS version.
2014-07-08 15:06:12:(ERROR) : ACU Configurator, Category: Exit: ***********Exit with code 37. Details: Error with the XML file. The value of the SCSVersion tag in the profile is not applicable to this Intel(R) SCS version.
The client information is as follows:
MEBx Version 9.0.0.0025
FW Version 9.0.20.1447
LMS Version 9.5.10.1628
MEI Driver Version 9.0.0.1287
MEI DeviceID PCI\VEN_8086&DEV_8C3A&SUBSYS_18E7103C&REV_04\3&11583659&0&B0
SOL Driver Version 9.5.10.1586
SOL DeviceID PCI\VEN_8086&DEV_8C3D&SUBSYS_18E7103C&REV_04\3&11583659&0&B3
Any ideas or potential solutions would be appreciated. FYI, I have changed the values in the xml file to match each one of the version values listed for the client with no joy.
Thanks in advance for any assistance.
TB
As a reminder, direct support from Intel engineers is available at https://bizsupport.intel.com/ https://bizsupport.intel.com.
Did you manage to solve this? I'm experiencing the exact same problem.
Sander.
Please note that Intel SCS 9 is EOL now.
Current version is Intel SCS 11 available at : https://downloadcenter.intel.com/product/39104/Intel-Setup-and-Configuration-Software-Intel-SCS- Drivers & Software
Please make sure to use same SCS Console/ACU Wizard to create AMT profile and same version of ACUConfig.exe/ACU.dll to perform configuration.
BTW in quoted case Intel AMT FW was : FW Version 9.0.20.1447 which is pretty old/ EOL'd
for Intel Q87 chipset based desktops please update Intel ME FW to the latest version 9.1.x supported by OEM (check OEM support web for specyfic HW model).
rgds
Dariusz Wittek
Intel EMEA Biz Client Solution Architect
