Intel vPro® Platform
3067 Discussions
i5-3320M (SR0MX) missing vPro
TBuko
My i5-3320M mobile CPU (SR0MX) is missing vPro which otherwise is advertised in ark.intel.com for this model CPU.
The laptop is HP 8470p
As you can see below: MEBx Version: 0.0.0.0000
Ctrl+P never showed up during boot and never worked
ACUWizard.exe (9.1.0.169) errors out with a SKU error:
ACUConfig.log http://pastebin.ca/2699326 http://pastebin.ca/2699326
http://s29.postimg.org/pczbu0cs7/Untitled.png http://s29.postimg.org/pczbu0cs7/Untitled.png
http://s29.postimg.org/hbovhby5z/SKUversion_Fail.png http://s29.postimg.org/hbovhby5z/SKUversion_Fail.png
Output of MeInfoWin.exe:
Intel(R) ME code versions:
BIOS Version: 68ICF Ver. F.46
Gbe Version: 1.5
VendorID: 8086
PCH Version: 4
FW Version: 8.1.52.1496
UNS Version: Not Available
LMS Version: 9.5.10.1628
MEI Driver Version: 8.1.10.1275
Wireless Hardware Version: 0.1.70
Wireless Driver Version: 15.10.5.1
FW Capabilities: 0x01301C60
Intel(R) Anti-Theft Technology - PRESENT/ENABLED
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
CPU Upgrade State: Not Upgradable
Cryptography Support: Enabled
Last ME reset reason: Power up
Local FWUpdate: Enabled
BIOS Config Lock: Enabled
GbE Config Lock: Enabled
Host Read Access to ME: Disabled
Host Write Access to ME: Disabled
SPI Flash ID # 1: C22018
SPI Flash ID VSCC # 1: 20052005
SPI Flash BIOS VSCC: 20050000
BIOS boot State: Post Boot
OEM Id: 00000000-0000-0000-0000-000000000000
Link Status: Link up
System UUID:
MAC Address:
IPv4 Address: 0.0.0.0
Configuration state: Not started
Provisioning Mode: None
Capability Licensing Service: Enabled
Capability Licensing Service Status: Permit info not available
OEM Tag: 0x00000000
Wireless Micro-code Mismatch: No
Wireless Micro-code ID in Firmware: 0x422B
Wireless LAN in Firmware: Intel(R) Centrino(R) Ultimate N 6300
Wireless Hardware ID: 0x422B
Wireless LAN Hardware: Intel(R) Centrino(R) Ultimate N 6300
Localized Language: English
Independent Firmware Recovery: Disabled
BAFFLING
I tried with different driver versions and firmware versions to find the exact same result.
Thank you.
TBuko
MEManufWin64.exe -verbose
Intel(R) MEManuf Version: 8.1.10.1286
Copyright(C) 2005 - 2012, Intel Corporation. All rights reserved.
FW Status Register1: 0x1E000245
FW Status Register2: 0x69000106
CurrentState: Normal
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: M0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
ICC: Valid OEM data, ICC programmed
Get FWU info command...done
Get FWU version command...done
Get FWU feature state command...done
Get ME FWU platform type command...done
Get ME FWU feature capability command...done
Feature enablement is 0x1301C60
gFeatureAvailability value is 0x1
Request Intel(R) ME test result command...done
ME initialization state valid
ME operation mode valid
Current operation state valid
ME error state valid
Verifying FW Status Register1...done
OEM ICC data valid and programmed correctly
vsccommn.bin was created on 03:27:24 06/19/2012 GMT
SPI Flash ID # 1 ME VSCC value is 0x2005
SPI Flash ID # 1 (ID: 0xC22018) ME VSCC value checked
SPI Flash ID # 1 BIOS VSCC value is 0x2005
SPI Flash ID # 1 (ID: 0xC22018) BIOS VSCC value checked
FPBA value is 0x0
Found an Intel vPro Wireless device
Request Intel(R) ME Full BIST test command...done
Get Intel(R) ME test data command...done
Total of 15 Intel(R) ME test result retrieved
Policy Kernel - Power Package: Live Heap Test - Passed
Common Services - LAN: Connectivity to NIC in M3 - Skipped
MicroKernel - Internal Hardware Tests: Internal Hardware Tests - Passed
Policy Kernel - ME Password: Validate MEBx password - Passed
Policy Kernel - Power Package: Package 1 supported - Passed
Policy Kernel - Power Package: Default package supported - Passed
MicroKernel - Blob Manager: Set - Passed
MicroKernel - Blob Manager: Get - Passed
MicroKernel - Blob Manager: Remove - Passed
Policy Kernel - ME Configuration: Wlan Power Well - Passed
Policy Kernel - ME Configuration: PROC_MISSING - Passed
Policy Kernel - ME Configuration: M3 Power Rails Available - Passed
Policy Kernel - ME Recovery: ME Recovery mode check - Passed
Policy Kernel - Embedded Controller: Power source type - Passed
Policy Kernel - SMBus: Read byte - Passed
Clear Intel(R) ME test data command...done
Get EPID Group ID command...done
EPID Group ID: 905
EPID GID Check passed
MEManuf Test Passed
