Intel vPro® Platform
3072 Discussions
unable to establish KVM session with (MBEx 6.0.0.1179) vPro enabled ProBook 6450
Unable to establish KVM session with (MBEx 6.0.0.1179) vPro Enabled Probook 6450. I have enabled ME set password and configure provisioning = none.
Now I am able to browse vPro enabled machine by http://pcname:portnumber and mange power state. But unable to connect to said machine by VNC Viewer 4 or Plus version. I have also tried to connect it by KVM 1.0.0.0; I've attached error screen shots, please advise in this regard.
(Note: There is no KVM option menu in MEBx)
(Intel Management and Security Status in taskbar (Win7) is showing Intel AMT = Enable , Intel RPAT =Disable)
Is your system using the Intel integrated graphics? I have found that if you look in your device manager and under display, if it doesn't say Intel integrated graphics I do not believe this will work even though you have AMT 6.
Hope that helps,
Matt
its specs on hp site shows Intel Integrated Graphics but it shows ATI Mobility Radeon HD 540v in Dispaly adapters (Device manager).
If intel integrated graphics is mandatory for KVM, then I think I cannot do anything except power management of AMT machine.
that's why KVM menu is missing from MBEx?
Jacob_G_Intel
You're correct, Intel Graphics is required for KVM Remote Control.
You can do other things besides power control. One of my favorite things is IDE Redirection. It allows you to remotly boot a vPro system from a CD or Floppy image file on the network. Serial over LAN will allow you to remotly see text based interfaces like linux, DOS, or BIOS. For GUI based interfaces (which is were KVM really shines) an alternative is to add a VNC server into the image. That way you can still conenct once the recovery image boot. It's not as nice as KVM, but you can still get the job done.
Remote ISO Launcher is a nice IDEr & SOL tool: /docs/DOC-5943 http://communities.intel.com/docs/DOC-5943
Here's how to build WinPE with a VNC Server. It makes a good recovery tool for use with vPro both with and without KVM: /docs/DOC-5095 http://communities.intel.com/docs/DOC-5095
Other reference designs are here: /docs/DOC-4080 http://communities.intel.com/docs/DOC-4080
I believe so Muhammad. I have the same issue on my HP 8440p. When ordering I guess I had to be more specific that the right graphics came with the laptop .
Thanks Jake and Matt ;
So to experience KVM, I have to wait for next lot of computer
I don't think graphics card has anything to do with it. I had a PCI-e graphics in my system
when I noticed there was no KVM option as well. I considered the idea of the graphics card,
so I removed the card and switched to the intergrated graphics. No difference. The system
is a Lenovo ThinkCentre M90 with Intel AMT 6.0.2.1194
