Intel vPro® Platform
2996 Discussions
vPro connections across the WAN
HBake
How would I connect to a vPro computer across a WAN?
Bruno_Domignues
Hughie,
You can connect to a vPro machine in the same way that you do locally, in the same LAN. AMT is based on TCP/IP that can be routed.
However, in case your vPro machine is behind a NAT, probably you will need to use CIRA (Client Initiated Remote Access) in order to reach these machines. - this features is available since AMT 4.0: http://software.intel.com/en-us/blogs/2008/10/09/new-with-intel-amt-4050-fast-call-for-help-and-remote-pc-assist-aka-cira/ http://software.intel.com/en-us/blogs/2008/10/09/new-with-intel-amt-4050-fast-call-for-help-and-remote-pc-assist-aka-cira/
Best Regards!
--bruno
