Intel vPro® Platform
2761 Discussions
what ports&services need to be permitted on the firewall for vPro management
If i want to manage vPro 3.0 with SMS under SMB mode, what ports and services do i need to open in the firewall? Is 16992 enough?
-Jennifer
Jennifer,
Here's a list I put together showing what ports are used and why. Hopefully this will provide you with the information you need.
80
Standard HTTP Port (Web UI)
443
Standard HTTPS Port (Web UI in SSL mode)
9971
Default port used by SCS/SCA (configurable)
16992
SOAP commands in SMB mode *
16993
SOAP commands in TLS/Enterprise mode **
16994
IDE-Redirection in SMB mode *
16995
IDE-Redirection in TLS/Enterprise mode **
56666
Serial over LAN (SOL)
*-16992 and 16994 are used during SMB mode, not used at all with TLS
**-16993 and 16995 are using during TLS, not used at all with SMB
