Items with no label
3340 Discussions
Any compatible driver or better than Intel® G41 Express chipset?
FEneq
This driver is an older graphics driver: Intel® G41 Express chipset. There is one that I can use that is compatible and in this way have a better performance of my PC. I'm waiting. Thanks in advance.
n_scott_pearson
It is true that the graphics engine in the G41 Express Chipset is not supported on Windows 10. Intel does not provide a driver. The Microsoft Compatibility driver will work, but is old and slow and not very compatible with the expected software interfaces. You can, however, install an add-in PCIe graphics card from NVIDIA or AMD/ATI and get around the limitations. Here are some links to articles that should provide you with an idea of the cards that should be compatible with your motherboard:
Hope this helps,
