Items with no label
3341 Discussions
Error converting a model
KDeep
Hi
I am trying to convert a model (20180402-114759.pb )using mo_tf.py but the following error is occurred could u help me with that
ERROR:
Common parameters:
               - Path to the Input Model:               /opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/20180402-114759.pb
               - Path for generated IR:              /home/icsltd/Desktop/FP16
               - IR output name:          20180402-114759
               - Log level:        ERROR
               - Batch:               Not specified, inherited from the model
               - Input layers:  Not specified, inherited from the model
               - Output layers:              Not specified, inherited from the model
               - Input shapes: Not specified, inherited from the model
               - Mean values: [127,127,127]
               - Scale values:  Not specified
               - Scale factor:   256.0
               - Precision of IR:             FP16
               - Enable fusing:               True
               - Enable grouped convolutions fusing:  True
               - Move mean values to preprocess section:       False
               - Reverse input channels:           False
TensorFlow specific parameters:
               - Input model in text protobuf format: False
               - Offload unsupported operations:        False
               - Path to model dump for TensorBoard:              None
               - List of shared libraries with TensorFlow custom layers implementation:             None
               - Update the configuration file with input/output node names:               None
               - Use configuration file used to generate the model with Object Detection API:               None
               - Operations to offload:              None
               - Patterns to offload:    None
               - Use the config file:     None
Model Optimizer version:          1.5.12.49d067a0
[ ERROR ] -------------------------------------------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
[ ERROR ] After re-inference of Mul1_13841 node, old and new shapes do not match. Old shapes: [array([], dtype=int64)], new shapes: [array([1])].
[ ERROR ] Traceback (most recent call last):
 File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/main.py", line 325, in main
   return driver(argv)
 File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/main.py", line 267, in driver
   mean_scale_values=mean_scale)
 File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 316, in tf2nx
   scale_input(graph, scale)
 File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/middle/passes/infer.py", line 338, in scale_input
   action=lambda graph, match: _scale_input_action_mul(graph, match, scale)
 File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/middle/pattern_match.py", line 95, in apply_pattern
   action(graph, match)
 File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/middle/passes/infer.py", line 338, in <lambda>
 File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/middle/passes/infer.py", line 318, in _scale_input_action_mul
   mul_node.create_node_with_data(inputs=[mul_input, mul_data], data_nodes=toutput)
 File "/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/ops/op.py", line 204, in create_node_with_data
   [data_node.shape for data_node in data_nodes])
AssertionError: After re-inference of Mul1_13841 node, old and new shapes do not match. Old shapes: [array([], dtype=int64)], new shapes: [array([1])].
[ ERROR ] ---------------- END OF BUG REPORT --------------
Thanks&regards
Deepika
MartyG
Although I do not have direct experience of model conversion with mo_tf, the guide by Intel I have linked to below may be useful to check your process against to see if something has been missed.
https://software.intel.com/en-us/articles/OpenVINO-Using-TensorFlow#inpage-nav-5
