Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Hi, We are planning interface D435i camera with xilinx ZCU104 board which has petalinux os running over that. Can i install realsense over petalinux platform. If yes Could you please provide the installation steps? Thanks, Manu
Operating system - Petalinux
Kernel version - 4.19
Language - C
Highlighted
Re: Hi, We are planning interface D435i camera with xilinx ZCU104 board which has petalinux os running over that. Can i install realsense over petalinux platform. If yes Could you please provide the installation steps? Thanks, Manu
The 400 Series cameras are extremely flexible in regard to the hardware that they will work with. As long as the hardware has an Intel or ARM processor of any type, you should be able to get the RealSense SDK installed on your Linux OS of choice by compiling the SDK from source code.
The link below, a case involving installing Librealsense on a Xilinx Ultra96 board with Petalinux, may be useful to you.
https://github.com/IntelRealSense/librealsense/issues/3040
Highlighted
Thanks for your reply.
Our board will come after two weeks. We will try that in it and reply back to you
Highlighted
Thank you very much. The RealSense forum has moved to a new location, so please bookmark it and post future questions there. Good luck!
https://support.intelrealsense.com/hc/en-us/community/topics
