Hi folks,
I have a problem with my random led blinker on fpga.
3-4 leds are turning "on" at the same time.
Although it is random, what I want is that only one led will be "on" at a time.
The code is provided.
module WhackAMole(
clk,
reset,
LED
input wire clk;
input wire reset;
output wire [7:0] LED;
wire [9:0] SYNTHESIZED_WIRE_0;
blinking_leds b2v_inst(
.clk(clk),
.reset(reset),
.rnd(SYNTHESIZED_WIRE_0),
.LED(LED));
randomnumbergenerator b2v_inst1(
.clk(clk),
.reset(reset),
.rnd(SYNTHESIZED_WIRE_0));
endmodule
module randomnumbergenerator (
input clk,
input reset,
output reg [9:0] rnd
wire feedback;
wire [9:0] lfsr_next;
//An LFSR cannot have an all 0 state, thus reset to non-zero value
reg [9:0] reset_value = 13;
reg [9:0] lfsr;
reg [31:0] count;
reg [31:0] counter;
// pragma translate_off
integer f;
initial begin
f = $fopen("output.txt","w");
end
// pragma translate_on
always @ (posedge clk or posedge reset)
begin
if (reset) begin
lfsr <= reset_value;
count <= 32'hF;
rnd <= 0;
end
else begin
lfsr <= lfsr_next;
count <= count + 1;
// a new random value is ready
if (count == 32'd9) begin
count <= 0;
rnd <= lfsr%8; //assign the lfsr number to output after 10 shifts
$fwrite(f,"%0d\n",rnd);
end
end
end
// X10+x7
assign feedback = lfsr[9] ^ lfsr[6];
assign lfsr_next = {lfsr[8:0], feedback};
always @ (*) begin
if (rnd == reset_value) begin
$fclose(f);
$finish();
end
end
endmodule
module blinking_leds (
input clk,
input reset,
input [9:0] rnd,
output [7:0] LED);
reg [31:0] counter;
reg [7:0] LED_status;
initial
begin
counter <= 32'b0;
LED_status <= 0;
end
always @(posedge clk or posedge reset)
begin
if (reset)
begin
counter <= 32'b0;
LED_status <= 0;
end
else if (counter > 5000000)
begin
case(rnd)
10'b0000000000: LED_status[0] <= !LED_status[0]; //0
10'b0000000001: LED_status[1] <= !LED_status[1]; //1
10'b0000000010: LED_status[2] <= !LED_status[2]; //2
10'b0000000011: LED_status[3] <= !LED_status[3]; //3
10'b0000000100: LED_status[4] <= !LED_status[4]; //4
10'b0000000101: LED_status[5] <= !LED_status[5]; //5
10'b0000000110: LED_status[6] <= !LED_status[6]; //6
10'b0000000111: LED_status[7] <= !LED_status[7]; //7
endcase
counter <= 32'b0;
end
else
begin
counter <= counter + 1'b1;
end
end
assign LED = LED_status;
endmodule
- Tags:
- Verilog
