Items with no label
3340 Discussions
Realsense ZR300 3D Model or Mechanical Description
Is there a 3D model of the ZR300 Developement Kit or Mechanical Description to download?
MartyG
I do not believe that a 3D model or CAD file for the ZR300 is available. They were not available for previous camera models either. The closest thing we have to that is a set of approximate general measurements of the casing of the ZR300 Developer Kit camera that was provided by Intel support member Sergio in February 2017.
X: 15.5cm
Y: 3.2cm
Z: 0.9cm
Hi boay1000,
Thank you for contacting us. We'll pass your request to have a 3D model and a Mechanical Descriptor guide to the right department. Thank you for your feedback.
For the moment, as MartyG pointed out, the measurements above can serve as approximate values.
We hope to have more documentation on the ZR300 released soon. Let us know if there's something else we can assist you with.
-Sergio A
Hi boay100,
Thank you for your patience. We want to update the case and let you know that the mechanical models for the ZR300 exist at:
Collada models are located here: https://github.com/IntelRealSense/realsense_samples_ros/tree/kinetic-devel/realsense_ros_camera/meshes realsense_samples_ros/realsense_ros_camera/meshes at kinetic-devel · IntelRealSense/realsense_samples_ros · GitHub
URDF models are located here: https://github.com/IntelRealSense/realsense_samples_ros/tree/kinetic-devel/realsense_ros_camera/urdf realsense_samples_ros/realsense_ros_camera/urdf at kinetic-devel · IntelRealSense/realsense_samples_ros · GitHub
Test launch files to view the models are located here: https://github.com/IntelRealSense/realsense_samples_ros/tree/kinetic-devel/realsense_ros_camera/launch realsense_samples_ros/realsense_ros_camera/launch at kinetic-devel · IntelRealSense/realsense_samples_ros · GitHub
Let us know if this is what you were looking for.
-Sergio A
