Can't see Media SDK filters in Graphedit
Frank_v_1
I'm a beginner with Directshow, but made my first application already. I'm able to capture and preview various cameras I use for the project I'm working on. However, all the capture content is RAW video, so huge in size. Therefore, I would like to use the Intel h264 encoder. I built my software in Labview, but first test my directshow setup in Graphedit. However, I don't see the Intel filters in Graphedit. I installed the media SDK, but that is how far I got.
I hope somebody has the patience to walk me through the process or give me some pointers where to look.
I was able to get other third-party encoders in graphedit.
Thank you,
Frank
Surbhi_M_Intel
Hi Frank,
Glad to know your application is going well. Here is article which describes how one can add Intel Media SDK decoder and encoder in the graphedit pipeline. I hope this answers your question. If you do see any issue, please let us know.
-Surbhi
Frank_v_1
Hi Surbhi,
Thanks for you response, but this is not the problem I'm facing. I have installed the media SDK, but I'm unable to find the Intel Filters in my graphedit filter list. So, I cannot even add them to the pipeline. Is there any .dll or .ax file I need to register?  Or could the problem be somewhere else?
-Frank
Shaojuan_Z_Intel
Hi Frank,
You are right that those DLLs need to be registered to be available in Graphedit. If you are using 64-bit Graphedit, please register 64-bit DLLs, and similarly register 32-bit DLLs if you are using 32-bit Graphedit. Also, to register 64-bit DLLs, please make sure to use regsvr32 under c:\Windows\SysWOW64, since by default regsvr32 might be for 32-bit. In either case, please run regsvr32 as administrator. Hope this helps. Thanks!
Frank_v_1
And which DLLs do I need to register? Because I did the mfx_mft_h264ve_w7_32.dll, but I can't find it in the list.
Thanks for the help!
Shaojuan_Z_Intel
Hi Frank,
From your original post, looks like you need h264 encoder filter, which is in our deprecated sample package that can be downloaded here https://software.intel.com/en-us/intel-media-server-studio-support/code-samples. Those deprecated samples are no longer tested or verified in the current MediaSDK, but you can still add h264_enc_filter.dll in Graphedit.
