Gray Video
Guilherme_L_2
I'm new in mfxlib and i'm trying to make a test with camera capture.
I'm working in a video conference software and i want to change the encode process from x264 lib to Intel quick sync
So, i have this YUV420 frame with YV12 fourcc with a known format and i'm trying to encode and record an h264 video in a .mp4 container to see if the encode method is working fine, but the result is always a gray frame with some  weird squares and some colors appearing randomly.
I'm basically using vpp to convert the YV12 frame to NV12 and after that using encode to h264, i think the problem is in the parameters or in the output frame allocation, the idea is to keep it simple for tests and make otimization after.
I have learning by myself looking in sample_encode, simple_encode, simple_vpp and sample_vpp, so if you find some very strange things in my code, please let me know
some code:
Parameter iniciailization:
[cpp]
//encParameters
convertFrameRate(30, &(mfxEncParams->mfx.FrameInfo.FrameRateExtN), &(mfxEncParams->mfx.FrameInfo.FrameRateExtD));
mfxEncParams->mfx.CodecId = MFX_CODEC_AVC;
mfxEncParams->mfx.TargetUsage = MFX_TARGETUSAGE_BALANCED;
mfxEncParams->mfx.TargetKbps = 2000;
mfxEncParams->mfx.RateControlMethod = MFX_RATECONTROL_VBR;
mfxEncParams->mfx.FrameInfo.FourCC = MFX_FOURCC_NV12;
mfxEncParams->mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
mfxEncParams->mfx.FrameInfo.PicStruct = MFX_PICSTRUCT_PROGRESSIVE;
mfxEncParams->mfx.FrameInfo.CropX = 0;
mfxEncParams->mfx.FrameInfo.CropY = 0;
mfxEncParams->mfx.FrameInfo.CropW = 320;
mfxEncParams->mfx.FrameInfo.CropH = 240;
mfxEncParams->mfx.EncodedOrder = 0;
mfxEncParams->mfx.FrameInfo.Width = MSDK_ALIGN16(mfxEncParams->mfx.FrameInfo.CropW);
mfxEncParams->mfx.FrameInfo.Height = (MFX_PICSTRUCT_PROGRESSIVE == mfxEncParams->mfx.FrameInfo.PicStruct)?
MSDK_ALIGN16(mfxEncParams->mfx.FrameInfo.CropH) : MSDK_ALIGN32(mfxEncParams->mfx.FrameInfo.CropH);
mfxEncParams->IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
//Vpp parameters
memset(mfxVppParams, 0, sizeof(mfxVideoParam));
/* input data */
mfxVppParams->vpp.In.FourCC = MFX_FOURCC_YV12;
mfxVppParams->vpp.In.CropX = 0;
mfxVppParams->vpp.In.CropY = 0;
mfxVppParams->vpp.In.CropW = 320;
mfxVppParams->vpp.In.CropH = 240;
// width must be a multiple of 16
// height must be a multiple of 16 in case of frame picture and
// a multiple of 32 in case of field picture
mfxVppParams->vpp.In.Width = MSDK_ALIGN16( mfxVppParams->vpp.In.CropW);
mfxVppParams->vpp.In.Height= MSDK_ALIGN16( mfxVppParams->vpp.In.CropH);
mfxVppParams->vpp.In.PicStruct = MFX_PICSTRUCT_PROGRESSIVE;
convertFrameRate(30, &(mfxVppParams->vpp.In.FrameRateExtN), &(mfxVppParams->vpp.In.FrameRateExtD));
/*output data */
memcpy(&mfxVppParams->vpp.Out, &mfxEncParams->mfx.FrameInfo, sizeof(mfxFrameInfo));
mfxVppParams->IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY | MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
[/cpp]
Surface init:
[cpp]
mfxFrameSurface1* inSurface = new mfxFrameSurface1;
memset(inSurface, 0, sizeof(mfxFrameSurface1));
mfxFrameSurface1* outSurface = new mfxFrameSurface1;
memset(outSurface, 0, sizeof(mfxFrameSurface1));
memcpy(&(inSurface->Info), &(par->vpp.In), sizeof(mfxFrameInfo));
memcpy(&(outSurface->Info), &(par->vpp.Out), sizeof(mfxFrameInfo));
inSurface->Data.Y = inFrame;
inSurface->Data.U = inSurface->Data.Y + ysize;
inSurface->Data.V = inSurface->Data.U + uvsize;
inSurface->Data.Pitch = mfxEncParams->mfx.FrameInfo.Width;
intermediateSurface->Data.Y = new mfxU8[ 320 * 240 * 12 / 8];
intermediateSurface->Data.U = intermediateSurface->Data.Y + ysize;
intermediateSurface->Data.V = intermediateSurface->Data.U + 1;
mfxBS = new mfxBitstream();
mfxBS->MaxLength = par->mfx.BufferSizeInKB * 1000;
mfxBS->Data = new mfxU8[mfxBS->MaxLength];
[/cpp]
VPP process:
[cpp]
mfxStatus sts = MFX_ERR_NONE;
for (;;)
 sts = mfxVpp->RunFrameVPPAsync(inSurface, outSurface, NULL, vppSyncp);
 if (MFX_ERR_NONE < sts && !(*vppSyncp)) // repeat the call if warning and no output
 if (MFX_WRN_DEVICE_BUSY == sts)
  Sleep(1); // wait if device is busy
else if (MFX_ERR_NONE < sts && *vppSyncp)
 sts = MFX_ERR_NONE; // ignore warnings if output is available
 break;
else
 break; // not a warning
// process errors
if (MFX_ERR_MORE_DATA == sts)
 printf("QuickSyncEncode : VPP : Error MFX_ERR_MORE_DATA\n");
else if (MFX_ERR_NONE != sts)
 printf("QuickSyncEncode : VPP : Error %d\n", sts);
[/cpp]
Encode Process:
[cpp]
sts = mfxEnc->EncodeFrameAsync(NULL, intermediateSurface, mfxBS, encSyncp);
if(sts == MFX_ERR_NONE)
 for (;;)
  if (MFX_ERR_NONE < sts && !(*encSyncp)) // Repeat the call if warning and no output
   printf("!syncp\n");
    printf("MFX_WRN_DEVICE_BUSY\n");
    Sleep(1); // Wait if device is busy, then repeat the same call
  else if (MFX_ERR_NONE <= sts && *encSyncp)
   sts = MFX_ERR_NONE; // Ignore warnings if output is available
   break;
  else if (MFX_ERR_NOT_ENOUGH_BUFFER == sts)
   printf("MFX_ERR_NOT_ENOUGH_BUFFER\n");
   // Allocate more bitstream buffer memory here if needed...
   break;
  else
   printf("waiting sync\n");
 if(MFX_ERR_NONE == sts)
  sts = mfxSession->SyncOperation(*encSyncp, 60000); // Synchronize. Wait until encoded frame is ready
  *outFrame = mfxBS->Data;
  *outFrameSize = mfxBS->DataLength;
[/cpp]
Guilherme
P.S.:sorry by the poor english
Guilherme_L_2
I made some progress, now my result video starts with that gray thing and after a while it's turn in a video with the expected aspect, but the video is too slow.
I had forgotten to set the frame pitch of the outSurface
Guilherme
dr_asik
The presence of a "Sleep(1)" could explain your issue. Sleep(1) doesn't really sleep 1 ms, it sleeps at least 1 ms; given the time granularity of the OS this can easily be 16ms or more. In any case, if your code is too slow, it's just a matter of taking time measures here and there to find out what is taking time.
Guilherme_L_2
I don't know if it's becouse i'm working with low resolution video but the "Sleep(1)" is never executed. And i don't had slow code, i had a slow .mp4 video. I have solved that a minute ago, i was passing a 10 fps value in  place of 30 to the ffmpeg.
The real problem continues to be the gray frames in the begining of the video.
In one of this videos i can see some shadows of movements made in the video i have recorded, so i think that could be something related with a missed I-frame
Guilherme_L_2
I have uploaded a sample
Petter_L_Intel
have you verified that the pure H.264 elementary stream output from encode is correct before muxing into a container? The provided clip seem to have may issues, such as invalid or skewed timestamps and stream corruptions.
Looking at the sample code you provided I noticed that VPP initialization is missing setting the output color space format. Since you are copying the VPP "In" data to the "Out" data it means that the output colorspace (fourcc) will also be YV12. Output must be set to NV12. In any case, since your code seem to execute successfully I suspect you may be setting it anyway, but not in the code snippet you provided?
What is the variable "ysize" and "uvsize" set to in your code?
Petter
Guilherme_L_2
Hi Petter,
I'm copying the mfx.FrameInfo to the vpp.Out, not the vpp.In, and that contain the output colorspace seted as NV12. (line 07 and 35 of the first block of code). The way i pasted the code here seems weird, but i made it this way because it is divided in different methods
ysize is the width * height, and the uvsize is width * height / 4.
Anyway, i solved the problem, and it's the gopsize parameter of the ffmpeg container settings are seted as 12 and the GopPicSize in the VPP Out data was not defined.
Thanks a lot.
Guilherme.
