HEVC height adjustement in 1080
svutran
I am currently working with the sample_encode application to encode 1920x1080 videos in HEVC. There is currently 8 extra lines that are being added at the bottom of the video during encoding in order to have a height of a multiple of 16.
In HEVC, there is supposed to be a way to also have a height of a multiple of 8. Is there a way to enable this and to not have extra lines added at the bottom of the frame?
AlekhyaV_Intel
Thank you for posting in Intel Communities. We have tried the sample_encode demo with a couple of videos with different resolutions & observed that the resolution of a video is increased by few lines to make it a multiple of 16. We are working on this internally to check if it is possible to have a resolution which is a multiple of 8. We'll get back to you with an update.
Alekhya
Dmitry_E_Intel
Hi @svutran ,
Please use PicWidthInLumaSamples and PicHeightInLumaSamples  to specify coded picture size.
Dmitry
AlekhyaV_Intel
Has the solution provided helped? Could you please give us an update regarding this issue?
Alekhya
svutran
We used instead -lowpower:on option on the sample_encode and no extra lines were added. It works.
AlekhyaV_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
