- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Moving it to the Media forum as it is more appropriate here.
Karthi
I use this Tutorial to to add video capturing capability to Unity applications on Android.:
And have this output after building the jar-file on Mac OS X:
Buildfile: /Users/user/Documents/app/Assets/Plugins/Android/build.xml
message:
[echo] Android Ant Build for Unity Android Plugin
[echo] message: Displays this message.
[echo] clean: Removes output files created by other targets.
[echo] compile: Compiles project's .java files into .class files.
[echo] build-jar: Compiles project's .class files into .jar file.
-dirs:
[echo] Creating output directory: Users/user/Documents/app/Assets/Plugins/Android/classes
[mkdir] Created dir: /Users/user/Documents/app/Assets/Plugins/Android/Users/user/Documents/app/Assets/Plugins/Android/classes
compile:
build-jar:
[zip] Warning: skipping zip archive /Users/user/Documents/app/Assets/Plugins/Android/Capturing.jar because no files were included.
clean-post-jar:
[echo] Removing post-build-jar-clean
[delete] Deleting directory /Users/user/Documents/app/Assets/Plugins/Android/Users/user/Documents/app/Assets/Plugins/Android/classes
BUILD SUCCESSFUL
Total time: 0 seconds
I use this directories:
<!-- Change this in order to match your configuration -->
<property name="sdk.dir" value="Users/user/NVPACK/android-sdk-macosx/SDK"/>
<property name="target" value="android-18"/>
<property name="unity.androidplayer.jarfile" value="Applications/Unity/Unity.app/Contents/PlaybackEngines/AndroidPlayer/development/bin/classes.jar"/>
<!-- Source directory -->
<property name="source.dir" value="Users/user/Documents/app/Assets/Plugins/Android" />
<!-- Output directory for .class files-->
<property name="output.dir" value="Users/user/Documents/app/Assets/Plugins/Android/classes"/>
Where is the problem?
Oli
- Balises:
- Development Tools
- Graphics
- Intel® INDE Setup and IDE Integration (Archived)
- Media Processing
- Optimization
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Oli,
We will check the video capturing tutorial building on Mac OS X and get back with further information.
Thanks, Alexey
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Alexey,
Thank you!
The question is why have I this output directory "/Users/user/Documents/app/Assets/Plugins/Android/Users/user/Documents/app/Assets/Plugins/Android/classes"
and not only this?
This is the issue:
Oli
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Oliver,
I've built jar-file on MacOS X successfully without any issues. Would you please provide your build.xml file? It seems something wrong with it.
Ilya
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Ilya,
here is my build.xml:
<?xml version="1.0" encoding="UTF-8"?>
<project name="UnityCapturing">
<!-- Name of the jar to be created. Please note that the name should match the name of the class and the name
placed in the AndroidManifest.xml-->
<property name="output.jarfile" value="Capturing.jar"/>
<!-- Creates the output directories if they don't exist yet. -->
<target name="-dirs" depends="message">
<echo>Creating output directory: ${output.dir} </echo>
<mkdir dir="${output.dir}" />
</target>
<!-- Compiles this project's .java files into .class files. -->
<target name="compile" depends="-dirs"
description="Compiles project's .java files into .class files">
<javac encoding="ascii" target="1.6" debug="true" destdir="${output.dir}" verbose="${verbose}" includeantruntime="false">
<src path="${source.dir}" />
<classpath>
<pathelement location="${sdk.dir}\platforms\${target}\android.jar"/>
<pathelement location="${source.dir}\domain-1.2.2415.jar"/>
<pathelement location="${source.dir}\android-1.2.2415.jar"/>
<pathelement location="${unity.androidplayer.jarfile}"/>
</classpath>
</javac>
</target>
<target name="build-jar" depends="compile">
<zip zipfile="${output.jarfile}"
basedir="${output.dir}" />
</target>
<target name="clean-post-jar">
<echo>Removing post-build-jar-clean</echo>
<delete dir="${output.dir}"/>
</target>
<target name="clean" description="Removes output files created by other targets.">
<delete dir="${output.dir}" verbose="${verbose}" />
</target>
<target name="message">
<echo>Android Ant Build for Unity Android Plugin</echo>
<echo> message: Displays this message.</echo>
<echo> clean: Removes output files created by other targets.</echo>
<echo> compile: Compiles project's .java files into .class files.</echo>
<echo> build-jar: Compiles project's .class files into .jar file.</echo>
</target>
</project>
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I fixed the issue, but now I have this error log on start recording:
11-20 11:36:10.096: I/OMXClient(25821): Using client-side OMX mux.
11-20 11:36:10.101: E/OMX-VENC-720p(188): Is component secure 0
11-20 11:36:10.193: I/VideoCapabilities(25821): Unsupported profile 4 for video/mp4v-es
11-20 11:36:10.205: I/OMXClient(25821): Using client-side OMX mux.
11-20 11:36:10.209: E/OMXMaster(25821): A component of name 'OMX.qcom.audio.decoder.aac' already exists, ignoring this one.
11-20 11:36:10.249: E/OMX-VENC-720p(188): set_parameter: metamode is valid for input port only
11-20 11:36:10.249: E/OMXNodeInstance(188): OMX_SetParameter() failed for StoreMetaDataInBuffers: 0x80001019
11-20 11:36:10.249: I/AudioFlinger(188): AudioFlinger's thread 0xb7886280 ready to run
11-20 11:36:10.250: E/ACodec(25821): [OMX.qcom.video.encoder.avc] storeMetaDataInBuffers (output) failed w/ err -2147483648
11-20 11:36:10.257: W/ACodec(25821): do not know color format 0x7f000789 = 2130708361
11-20 11:36:10.259: E/OMX-VENC-720p(188): WARNING: Unsupported Color format [2130708361]
11-20 11:36:10.259: E/OMX-VENC-720p(188): C2D init is successful
11-20 11:36:10.260: E/OMX-VENC-720p(188): WARNING: Unsupported Color format [2130708361]
11-20 11:36:10.260: E/OMX-VENC-720p(188): WARNING: Requested i/p bufsize[1181520],Driver's updated i/p bufsize = 1183744
11-20 11:36:10.262: E/OMX-VENC-720p(188): venc_set_intra_period: nPFrames = 30 nBFrames = 0
11-20 11:36:10.262: I/ACodec(25821): setupVideoEncoder succeeded
11-20 11:36:10.263: W/ACodec(25821): do not know color format 0x7f000789 = 2130708361
11-20 11:36:10.277: D/audio_hw_primary(188): select_devices: out_snd_device(0: none) in_snd_device(16: handset-mic)
11-20 11:36:10.277: E/ACDB-LOADER(188): Error: ACDB AudProc vol returned = -8
11-20 11:36:10.277: D/audio_hw_primary(188): enable_snd_device: snd_device(16: handset-mic)
11-20 11:36:10.280: D/audio_hw_primary(188): enable_audio_route: apply and update mixer path: audio-record
11-20 11:36:10.306: E/OMX-VENC-720p(188): Allocated virt:0xb36b4000, FD: 59 of size 1302528 at index: 0
11-20 11:36:10.307: E/OMX-VENC-720p(188): Allocated virt:0xb3576000, FD: 61 of size 1302528 at index: 1
11-20 11:36:10.329: E/OMX-VENC-720p(188): open Color conv for RGBA888
11-20 11:36:10.379: I/AMP(25821): New frame allocated for buffer 0
11-20 11:36:10.387: I/MPEG4Writer(25821): limits: 4294967295/0 bytes/us, bit rate: -1 bps and the estimated moov size 3072 bytes
11-20 11:36:10.392: I/AMP(25821): New frame allocated for buffer 0
11-20 11:36:10.396: I/AMP(25821): New frame allocated for buffer 1
11-20 11:36:10.407: I/MPEG4Writer(25821): setStartTimestampUs: 0
11-20 11:36:10.407: I/MPEG4Writer(25821): Earliest track starting time: 0
11-20 11:36:10.418: I/AMP(25821): New frame allocated for buffer 1
11-20 11:36:10.422: I/MPEG4Writer(25821): setStartTimestampUs: 99008
11-20 11:36:10.430: I/AMP(25821): New frame allocated for buffer 2
11-20 11:36:10.439: I/AMP(25821): New frame allocated for buffer 3
The created video file is not playable..
Nexus 4
Android 5.0
Oli
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
No solution?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Oliver,
I've checked it successfully on Nexus 5 with Android L.
Do you get corrupted output video every time?
Ilya
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hey Ilya,
yes, I get currupted output video every time.
Oli
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
