Dear support,
I'm trying to use the MFXVideoENC_Query function to determine the maximum possible target bitrate for different video resolutions. Unfortunately, the function always returns MFX_ERR_UNSUPPORTED no matter what structures or attributes I feed in (I tried mode 1. and mode 2.).
Plattform is Intel i3-4330 / HD 6400 / Win10 x64 / MediaSDK 2016 / H.264 HW encode / API Version 1.20 / GPU driver version June 9th 2017.
The actual encoding works properly.
As I understand from the Reference Manual the CodecId attribute (MFX_CODEC_AVC) is the only one must have parameter in the mfxVideoParam structure in order to receive a valid result. Can you advise how to get the MFXVideoENC_Query function to work as expected ?
Thank you,
Stefan.
Hi Stefan,
You're using wrong function. MFXVideoENC_Query is a member of MFXVideoENC class that performs the first step of encoding process – motion estimation, intraprediction and mode decision. Most probably you need to use MFXVideoENCODE_Query from MFXVideoENCODE
class that performs the entire encoding pipeline from the input video frames to the output bitstream instead.
Best wishes,
Anna
Hi Stefan,
Best wishes,
Anna
Hi Anna,
using MFXVideoENCODE_Query() instead of MFXVideoENC_Query() solved it. This was a tough one, especially since both functions are using identical parameters.
Anyway, thanks for your help,
Stefan.
