Linux Stream.local 4.4.0 #1 SMP Wed Sep 7 12:00:18 CEST 2016 x86_64 x86_64 x86_64 GNU/Linux
CPU0: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (family: 0x6, model: 0x3c, stepping: 0x3)
- cuda_8.0.27.1_linux
cat /etc/environment
# CUDA
CUDA_HOME=/usr/local/cuda
LIBVA_DRIVER_NAME=iHD
LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
LD_LIBRARY_PATH="/usr/local/cuda/lib64:/opt/intel/opencl:/usr/local/lib:/usr/lib64"
cd /opt/intel/mediasdk/opensource/libdrm/2.4.66-55964/
tar xf libdrm-2.4.66.tar.bz2
cd libdrm-2.4.66
./configure
make -j 8
make install
tar xf libva-1.67.0.pre1.tar.bz2
cd libva-1.67.0.pre1
./configure --enable-static
make -j 8
make install
mkdir build
cd build
cmake –D__ARCH:STRING=intel64 ../
make -j 8
prefix=/opt/intel/mediasdk
exec_prefix=${prefix}
libdir=${prefix}/lib/lin_x64
includedir=${prefix}/include
Description: Intel Media Server Studio SDK
Version: 16.4.2
Requires:
Libs: -L${libdir} -lmfx -lva -lstdc++ -ldl -lva-drm -ldrm
Cflags: -I${includedir} -I/usr/local/include/libdrm
# ls -l /dev/dri
crwxrwxrwx 1 vlc vlc 226, 0 Sep 14 11:23 card0
crwxrwxrwx 1 vlc vlc 226, 64 Sep 14 11:23 controlD64
crwxrwxrwx 1 vlc vlc 226, 128 Sep 14 11:23 renderD128
error: can't connect to X server!
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.5.55964-ubit
vainfo: Supported profile and entrypoints
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: <unknown entrypoint>
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : <unknown entrypoint>
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : <unknown entrypoint>
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : <unknown entrypoint>
VAProfileVP9Profile0 : <unknown entrypoint>
<unknown profile> : VAEntrypointVideoProc
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : <unknown entrypoint>?
Multi Transcoding Sample Version 7.0.16053497
Input #0, mpegts, from 'udp://@239.23.0.101:1234':
Duration: N/A, start: 36732.375211, bitrate: N/A
Program 261
Stream #0:0[0x7d1]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x7d2](cze): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s
Stream #0:2[0x7d4](cze): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, mono, s16p, 64 kb/s (visual impaired)
Stream #0:3[0x7d6](cze): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
[h264_qsv @ 0x40e9200] Error initializing the encoder
Output #0, mp4, to 'out.qsv.mp4':
Stream #0:0: Unknown: none, SAR 1:1 DAR 0:0
Metadata:
encoder : Lavc57.55.101 h264_qsv
Stream #0:1(cze): Unknown: none
Metadata:
encoder : Lavc57.55.101 aac
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_qsv))
Stream #0:1 -> #0:1 (mp2 (native) -> aac (native))
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
- « Previous
- 1
- 2
- Next »
huihai lu wrote:
I saw CUDA stuff in your post, so I assume you have a Nvidia graphic card in your system. Have you been able to enable both Nvidia graphic card and Intel GPU at the same time, and get MSS2017 to work?
yes, I use QSV (i7-6700K) and nvenc (Quadro M4000) together in the same time without problems. MSS2017.
Manuel M. wrote:
i have the same problem with ubuntu 16.04. I've installed everything as shown in the first post. But when i try to run the sample i got these error:
./sample_multi_transcode -i::h264 content/test_stream.264 -o::h264 /home/manuelmenz/out.h264 -hw -la
[sudo] password for manuelmenz:
Multi Transcoding Sample Version 7.0.16053497libva info: VA-API version 0.99.0
libva info: va_openDriver() returns 0Return on error: error code -2, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/pipeline_transcode.cpp 3372
Return on error: error code -2, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/sample_multi_transcode.cpp 277
I can not download the sys_analyzer script because the server is unavailable...
Seeing the same problem, did you ever figure out what was wrong?
i need support from the Community to install Intel Media Server 2017 oder 2017 R2 on my local Ubuntu.
Now, I install it successful on CentOS, but I need Ubuntu 14 or 16 not important.
if someone successfully installed Intel Media Server 2017 or 2017 R2 on my Ubuntu, then I am willing to pay for it
My last try I attached.
My Hardware: Intel i7 6700k, Asus Prime B250M-k
Best regards
- « Previous
- 1
- 2
- Next »
