I have installes all correct and patch the linux v4.4.0 Kernel too. But if I wold use the mfx encoder, the kernel shows an error.
./sys_analyzer_linux.py -------------------------- Hardware readiness checks: -------------------------- [ OK ] Processor name: Intel(R) Celeron(R) CPU G3900T @ 2.60GHz [ ERROR ] Processor not Xeon or Core. Not supported. -------------------------- OS readiness checks: -------------------------- [ OK ] GPU visible to OS -------------------------- Media Server Studio Install: -------------------------- [ OK ] user in video group [ OK ] libva.so.1 found [ OK ] vainfo reports valid codec entry points [ OK ] /dev/dri/renderD128 connects to Intel i915 -------------------------- Component Smoke Tests: -------------------------- [ OK ] Media SDK HW API level:Illegal instruction (core dumped) [ OK ] Media SDK SW API level:Illegal instruction (core dumped) [ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK -------------------------- Media SDK Plugins available: (for more info see /opt/intel/mediasdk/plugins/plugins.cfg) -------------------------- H264LA Encoder = 588f1185d47b42968dea377bb5d0dcb4 VP8 Decoder = f622394d8d87452f878c51f2fc9b4131 HEVC Decoder = 33a61c0b4c27454ca8d85dde757c6f8e HEVC Encoder = 6fadc791a0c2eb479ab6dcd5ea9da347
dmesg -->
[734.643615] traps: msdkcheck[3138] trap invalid opcode ip:7f109c2525b7 sp:7ffe9ca088c0 error:0 in libmfxhw64-p.so.1.19[7f109c050000+aa7000]
[ 735.104032] traps: msdkcheck[3141] trap invalid opcode ip:7f12b7b4ce77 sp:7ffedf28c2a0 error:0 in libmfxsw64-p.so.1.19[7f12b79e4000+7b2000]
#: vainfo error: XDG_RUNTIME_DIR not set in the environment. error: can't connect to X server! libva info: VA-API version 0.99.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.99 (libva 1.3.1) vainfo: Driver version: 16.5.55964-ubit vainfo: Supported profile and entrypoints VAProfileNone : VAEntrypointVideoProc VAProfileNone : <unknown entrypoint> VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : <unknown entrypoint> VAProfileH264Main : <unknown entrypoint> VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : <unknown entrypoint> VAProfileH264High : <unknown entrypoint> VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: <unknown entrypoint> VAProfileH264ConstrainedBaseline: <unknown entrypoint> VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : <unknown entrypoint>
What can I do and what can I check?
From the release notes at https://software.intel.com/sites/default/files/media_server_studio_essentials_release_notes_linux.pdf, Celeron processors are not supported.
Intel® Media Server Studio – SDK supports the following platforms with integrated graphics:
- Intel® Xeon® E3-1200 v4 Family with C226 chipset
- Intel® Xeon® E3-1200 and E3-1500 v5 Family with C236 chipset
- 5th Generation Intel® Core™
- 6th Generation Intel® Core™
Why this? The new Celerons does support QSV H264 and HEVC encoding and decoding
Hello, I have OT question....
Where can i find sys_analyzer_linux.py script?
