android stream has lag and noisy.
Jong_Youl_P_
Hi, guys~
My app is based on the camera streaming sample.
It streamed vide clips to wowza server on 20~25fps.
But sometimes the lag has happened, it happens two or three times in a minute.
And the lag remains about 5 seconds when it happens.
What can I do for it?
I tested the app using Samsung galaxy grand Max (http://www.gsmarena.com/samsung_galaxy_grand_max-6905.php)
Harshdeep_B_Intel
Hi Jong Youl,
In this scenario, lag observed could be due to network bandwidth speeds. Please check your network Upload/Download speeds. We tested on high network bandwidth and did not see any lag issues.
Following are some options you can try to workaround the lag:
  • Check you network bandwidth as device camera captures  4128 x 3096 resolution and this requires high network bandwidth to stream to Wowza server. If network bandwidth is low, I suggest trying on higher bandwidth.
  • If you have any other devices connected on same network hub, I suggest reconnecting them on different network.
  • If you have any antivirus blocker app on the device, suggest disabling it, before launching camera streaming app.
