Hi everyone, I have an application in which I use libvpl to do some accelerated encoding. I have configured the environment and run successfully my application on one machine that features a Meteor Lake-P [Intel Arc Graphics] 14th gen. On that machine if I use
system_analyzer
I see that the mfx-gen implementation is recognized
Implementation #0: mfx-gen
Library path: /opt/intel/mediasdk/lib/libmfx-gen.so.1.2.14
AccelerationMode: MFX_ACCEL_MODE_VIA_VAAPI
ApiVersion: 2.14
Impl: MFX_IMPL_TYPE_HARDWARE
ImplName: mfx-gen
MediaAdapterType: MFX_MEDIA_INTEGRATED
VendorID: 0x8086
DeviceID: 0x7D55
GPU name: unknown (arch=na codename=na)
PCI BDF: 0000:00:02.00
PCI RevisionID: 0x0008
DRMRenderNodeNum: 128
DeviceName: mfx-gen
To get this working I had to set
export LD_LIBRARY_PATH=/opt/intel/mediasdk/lib:$LD_LIBRARY_PATH
otherwise the method
MFXVideoENCODE_Query
always return -3.
Now, with the exact same application, when I try to execute it on another machine, while I setup the environment variables similar to the first machine, my application always fails.
First of all, even if I expose the path to the libmfx-gen.so, this implementation is not recognized. That machine features a UHD Graphics 630 (Mobile) 9.5 gen. The system_analyzer output is:
Implementation #0: mfxhw64
Library path: /opt/intel/mediasdk/lib/libmfxhw64.so.1.35
ApiVersion: 1.35
ImplName: mfxhw64
MediaAdapterType: MFX_MEDIA_UNKNOWN
VendorID: 0x8086
DeviceID: 0x3E9B
PCI BDF: FFFFFFFF:FFFFFFFF:FFFFFFFF.FFFFFFFF
PCI RevisionID: 0xFFFF
DeviceName: mfxhw64
Whenever I try to execute my application
always return -3.
Even though the second machine doesn't recognize the mfx-gen implementation, I can successfully run the libvpl legacy_encoder example.
At that point I am hitting a dead end, and can't understand first why mfx-gen implementation is not found and second why even if it is not, why the libvpl legacy_encoder example works successfully when it calls
but my application is failing on that method
Vainfo on the failing machine:
Trying display: wayland
Trying display: drm
libva info: VA-API version 1.23.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /home/integration/media-driver-workspace/build_media/media_driver/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_23
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.23 (libva 2.23.0.pre1)
vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 25.1.0 (30a39afb6)
vainfo: Supported profile and entrypoints
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : VAEntrypointStats
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointFEI
VAProfileH264Main : VAEntrypointEncSliceLP
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointFEI
VAProfileH264High : VAEntrypointEncSliceLP
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointFEI
VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointFEI
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
