Regarding vaapih264enc, as far as I checked with gst-inspect-1.0,
- width : 1 ~ 2147483647
- height : 1 ~ 2147483647
- framerate : 0/1 ~ 2147483647/1
However, even within these ranges, GStreamer may crash with a segfault depending on the combination of resolution, frame rate, and bit rate.
The frequency of crashes has the following trends:
- The smaller the resolution, the more likely it is to occur.
- The lower the frame rate, the more likely it is to occur.
- The higher the bit rate, the more likely it is to occur.
The following is an example of a combination that causes a crash.
- Resolution : 320 x 320
- Frame rate : 5 fps
- Bitrate : 8 Mbps
Regarding the above symptoms, where should I review?
Regarding vaapih264enc, are there any restrictions on input data or setting values?
environment :
- CPU : Atom-x5 E3930
- Linux Kernel : 5.10.115-cip7
- GStreamer : 1.20.5
