when compiling my project with MSVC++ 2005 and the latest Media SDK 3 beta, I'm getting these warnings:
libmfx.lib(main.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib' or at 'vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_critical_section.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib' or at 'vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_dispatcher.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib' or at 'vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_dxva2_device.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib' or at 'vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_function_table.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib' or at 'vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_library_iterator.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib' or at 'vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_load_dll.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib' or at 'vc80.pdb'; linking object as if no debug info
libmfx.lib(mfx_win_reg_key.obj) : warning LNK4099: PDB 'vc80.pdb' was not found with 'libmfx.lib' or at 'vc80.pdb'; linking object as if no debug info
A google search leads me to this:
http://social.msdn.microsoft.com/forums/en-US/vclanguage/thread/e3d0fcf4-84e5-478e-a44e-131449408df3/
Are you compiling the libmfx.lib with /Zi or /ZI? If so, would it be possible to compile the next release without /Zi and /ZI to fix these warnings?
Thanks!
Hi Nina,
thank you for your reply. The problem occurs when we link (during a rebuild) the Debug build, so it's libmfxmd.lib that's causing problems. I have just reinstalled the SDK from http://registrationcenter-download.intel.com/akdlm/irc_nas/2464/w_MSDK-2012_p_3.0.014_GOLD.zip . Here are the MD5 checksums if that helps:
G:\dev\src\ThirdParty\IntelMediaSDK\lib\win32>fciv -md5 libmfxmd.lib
// File Checksum Integrity Verifier version 2.05.
aae749e3e827a0df76a9ec6943ae6dd1 libmfxmd.lib
90f0779fcea099473e9a144b4276f7b5 libmfx.lib
The linker warnings:
1>libmfxmd.lib(main.obj) : warning LNK4099: PDB "vc80.pdb" wurde nicht mit "libmfxmd.lib(main.obj)" oder an "G:\dev\src\test\vc80.pdb" gefunden; Objekt wird verknpft, als ob keine Debuginformationen vorhanden wren.
1>libmfxmd.lib(mfx_critical_section.obj) : warning LNK4099: PDB "vc80.pdb" wurde nicht mit "libmfxmd.lib(mfx_critical_section.obj)" oder an "G:\dev\src\test\vc80.pdb" gefunden; Objekt wird verknpft, als ob keine Debuginformationen vorhanden wren.
1>libmfxmd.lib(mfx_dispatcher.obj) : warning LNK4099: PDB "vc80.pdb" wurde nicht mit "libmfxmd.lib(mfx_dispatcher.obj)" oder an "G:\dev\src\test\vc80.pdb" gefunden; Objekt wird verknpft, als ob keine Debuginformationen vorhanden wren.
1>libmfxmd.lib(mfx_dxva2_device.obj) : warning LNK4099: PDB "vc80.pdb" wurde nicht mit "libmfxmd.lib(mfx_dxva2_device.obj)" oder an "G:\dev\src\test\vc80.pdb" gefunden; Objekt wird verknpft, als ob keine Debuginformationen vorhanden wren.
1>libmfxmd.lib(mfx_function_table.obj) : warning LNK4099: PDB "vc80.pdb" wurde nicht mit "libmfxmd.lib(mfx_function_table.obj)" oder an "G:\dev\src\test\vc80.pdb" gefunden; Objekt wird verknpft, als ob keine Debuginformationen vorhanden wren.
1>libmfxmd.lib(mfx_library_iterator.obj) : warning LNK4099: PDB "vc80.pdb" wurde nicht mit "libmfxmd.lib(mfx_library_iterator.obj)" oder an "G:\dev\src\test\vc80.pdb" gefunden; Objekt wird verknpft, als ob keine Debuginformationen vorhanden wren.
1>libmfxmd.lib(mfx_load_dll.obj) : warning LNK4099: PDB "vc80.pdb" wurde nicht mit "libmfxmd.lib(mfx_load_dll.obj)" oder an "G:\dev\src\test\vc80.pdb" gefunden; Objekt wird verknpft, als ob keine Debuginformationen vorhanden wren.
1>libmfxmd.lib(mfx_win_reg_key.obj) : warning LNK4099: PDB "vc80.pdb" wurde nicht mit "libmfxmd.lib(mfx_win_reg_key.obj)" oder an "G:\dev\src\test\vc80.pdb" gefunden; Objekt wird verknpft, als ob keine Debuginformationen vorhanden wren.
FYI, I still see this issue with VS2012 + libmfx.lib from Media SDK 2014 for Client.
I know Microsoft will fix this issue by allowing us to ignore this warning. Our project still stays on VS2012 for a while, though :-(
http://connect.microsoft.com/VisualStudio/feedback/details/176188/can-not-disable-warning-lnk4099
I hope Intel can simply provides PDB associated with this libmfx.lib, though.
It's a few years since the original post, yet this issue still occurs with libmfx.lib.
It would be great to have these noisy warning removed by intel since LNK4099 is not ignorable on VS2010 and earlier.
Another vote for fixing this.
libmfx is open source. Source files can be found at \MediaSDK\opensource\mfx_dispatch. You can build desired library yourself: for any vs/crt version, with or without debug symbols, etc.
