运行sample_encode_x11两次, 同样的命令第一次成功, 第二次报错, 报错内容为-7
崇龙_战_
hello
  我安装intel media sdk R6版本在ubuntu 上, ubuntu是14.04.3
uname -a
Linux suirui 3.19.0-25-generic #26~14.04.1-Ubuntu SMP Fri Jul 24 21:16:20 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
我安装文档的generic 的方式安装的, 然后编译sample MediaSamples_Linux_6.0.16043175.175, 产生了sample_encode_x11 bin文件, 然后我使用命令./sample_encode_x11 h264 -i test_stream_176x96.yuv -o 3.264 -w 176 -h 96  -vaapi
第一次运行正常, 产生了h264文件
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Encoding Sample Version 0.0.000.0000
Input file format       YUV420
Output video            AVC
Source picture:
        Resolution      176x96
        Crop X,Y,W,H    0,0,176,96
Destination picture:
        Resolution      176x96
Frame rate      30.00
Bit rate(Kbps)  112
Target usage    balanced
Memory type     d3d
Media SDK impl          hw
Media SDK version       1.16
Processing started
Frame number: 101
Processing finished
同样的命令第二次报错了
Output video            AVC
Source picture:
        Resolution      176x96
        Resolution      176x96
Frame rate      30.00
Bit rate(Kbps)  112
Memory type     d3d
Media SDK impl          hw
Processing started
Return on error: error code -7, /home/suirui/MediaSamples_Linux_6.0.16043175.175/samples/sample_encode/src/pipeline_encode.cpp  1212
Return on error: error code -7, /home/suirui/MediaSamples_Linux_6.0.16043175.175/samples/sample_encode/src/pipeline_encode.cpp  1367
Return on error: error code 1,  /home/suirui/MediaSamples_Linux_6.0.16043175.175/samples/sample_encode/src/sample_encode.cpp    678
第三次再运行该命令又正常了, 我查了一下该错误, 是MFX_ERR_LOCK_MEMORY, 是什么原因产生的?
崇龙_战_
使用的设备是intel NUC NUC5i5RYK
Sravanthi_K_Intel
Hello there - Closing this thread since you started another one for the same topic, and have Intel folks working with you. Thanks.
