4th i7 better than 6th i5 in h.264 encoding?
高__超
I have used sample_encode in Intel Media SDK Samples 2016 6.0.0.142 to convert video from YUV420p to h.264, and used Evalvid to calculate PSNR  and SSIM.
I have found that PSNR and SSIM performed better in i7-4702mq than i3-4160 and i5-6400.
The enviroment is :
i7-4702mq + 4G DDR3 1600MHz * 2 + Win 8.1 x64
i3-4160 + 2G DDR3 1600MHz * 2 + Win7 x64
i5-6400 + 8G DDR4 2133MHz * 2 + Win7 x64
The command line is :
sample_encode h264 -w 1920 -h 1080 -f 24 -b 1000 -i input.yuv -o output.264 -hw
I have run the encoding program in the same command line, and changed the resolution and bitrate as follow.
500kbps 1000kbps 2000kbps in 720p
1000kbps 2000kpbs 4000kbps in 1080p
The result is :
video resolution bitrate PSNR SSIM
i3-4160 i7-4702m i5-6400 i3-4160 i7-4702m i5-6400
afd 1080 1000 37.198 38.208 37.237 0.919 0.925 0.919
2000 40.676 41.506 40.715 0.951 0.956 0.950
4000 43.449 44.200 43.514 0.970 0.973 0.970
720 500 36.185 37.014 36.156 0.898 0.905 0.897
1000 39.435 40.246 39.500 0.937 0.942 0.937
2000 42.312 43.096 42.299 0.962 0.966 0.962
ring 1080 1000 38.820 40.273 38.675 0.937 0.944 0.938
2000 44.344 45.622 44.399 0.966 0.971 0.967
4000 48.389 49.178 48.430 0.981 0.983 0.981
720 500 37.789 39.097 37.615 0.921 0.930 0.922
1000 42.955 44.186 42.947 0.956 0.961 0.956
2000 46.760 47.737 46.850 0.974 0.977 0.975
PSNR in i7-4702mq is about 1dB higher than i3-4160 and i5-6400 and SSIM in i7-4702mq is also higher than i3-4160 and i5-6400.
Is there a big different between i7 and i3, i5 when h.264 encoding?
高__超
There may be something wrong with the table.
Anna_B_Intel
Hi Gao,
Thank you for a report. Could you please provide me input video files that you used?
Best wishes,
Anna
高__超
Hi Anna,
Thank you for your reply.
I have used two videos:
afd_source_1080p_8000kbps.mov: http://pan.baidu.com/s/1dFuiQ5b
ring_source_1080p_10000kbps.mov: http://pan.baidu.com/s/1hrMSN5a
I use ffmpeg to convert them to YUV420p. And because they are too large, I only use parts of them. Below are the comand lines:
ffmpeg -ss 00:00:00 -i afd_source_1080p_8000kbps.mov -t 00:00:42 -s 1920x1080 -y -an -pix_fmt yuv420p  afd_1080.yuv
ffmpeg -ss 00:00:00 -i afd_source_1080p_8000kbps.mov -t 00:00:42 -s 1280x720 -y -an -pix_fmt yuv420p  afd_720.yuv
ffmpeg -ss 00:00:30 -i ring_source_1080p_10000kbps.mov -t 00:00:18 -s 1920x1080 -y -an -pix_fmt yuv420p  ring_1080.yuv
Anna_B_Intel
I can't download video from these links because of network error. Could you please compress files and attach to a comment at this topic?
Best wishes,
Anna
高__超
The videos are uploaded in the attachment.
Anna_B_Intel
Thanks for providing files. What exact PSNR and SSIM did you use: PSNR-Y, PSNR-U, PSNR-V or PSNR-O? Is it average PSNR/SSIM or you measured worst case numbers?
Best wishes,
Anna
高__超
I get PSNR(among Y, U and V)/SSIM of each frame, and calculate the average of them.
高__超
Hi Anna,
Have you got the results of encoding performances between 4th i7 and 6th i5?
Look forward to your soonest reply. Thanks.
david123456
Hi Anna,
It's very interesting from gao c's results. Could you confirm the results?
David
Anna_B_Intel
Sorry for delayed reply. I tried to reproduce the problem on i5-6260U (Skylake) and i7-4770K (Haswell), but PSNR and SSIM results were similar or even Skylake produced a little bit better quality. Check that you have the latest drivers and Media SDK/ Media Server Studio versions. Also you can update Samples version from here: https://github.com/Intel-Media-SDK/samples
Best wishes,
Anna
