I have used sample_encode in Intel Media SDK Samples 2016 6.0.0.142 to convert video from YUV420p to h.264, and used Evalvid to calculate PSNR and SSIM.
I have found that PSNR and SSIM performed better in i7-4702mq than i3-4160 and i5-6400.
The enviroment is :
i7-4702mq + 4G DDR3 1600MHz * 2 + Win 8.1 x64
i3-4160 + 2G DDR3 1600MHz * 2 + Win7 x64
i5-6400 + 8G DDR4 2133MHz * 2 + Win7 x64
The command line is :
sample_encode h264 -w 1920 -h 1080 -f 24 -b 1000 -i input.yuv -o output.264 -hw
I have run the encoding program in the same command line, and changed the resolution and bitrate as follow.
500kbps 1000kbps 2000kbps in 720p
1000kbps 2000kpbs 4000kbps in 1080p
The result is :
video | resolution | bitrate | PSNR | SSIM | ||||
i3-4160 | i7-4702m | i5-6400 | i3-4160 | i7-4702m | i5-6400 | |||
afd | 1080 | 1000 | 37.198 | 38.208 | 37.237 | 0.919 | 0.925 | 0.919 |
2000 | 40.676 | 41.506 | 40.715 | 0.951 | 0.956 | 0.950 | ||
4000 | 43.449 | 44.200 | 43.514 | 0.970 | 0.973 | 0.970 | ||
720 | 500 | 36.185 | 37.014 | 36.156 | 0.898 | 0.905 | 0.897 | |
1000 | 39.435 | 40.246 | 39.500 | 0.937 | 0.942 | 0.937 | ||
2000 | 42.312 | 43.096 | 42.299 | 0.962 | 0.966 | 0.962 | ||
ring | 1080 | 1000 | 38.820 | 40.273 | 38.675 | 0.937 | 0.944 | 0.938 |
2000 | 44.344 | 45.622 | 44.399 | 0.966 | 0.971 | 0.967 | ||
4000 | 48.389 | 49.178 | 48.430 | 0.981 | 0.983 | 0.981 | ||
720 | 500 | 37.789 | 39.097 | 37.615 | 0.921 | 0.930 | 0.922 | |
1000 | 42.955 | 44.186 | 42.947 | 0.956 | 0.961 | 0.956 | ||
2000 | 46.760 | 47.737 | 46.850 | 0.974 | 0.977 | 0.975 |
PSNR in i7-4702mq is about 1dB higher than i3-4160 and i5-6400 and SSIM in i7-4702mq is also higher than i3-4160 and i5-6400.
Is there a big different between i7 and i3, i5 when h.264 encoding?
There may be something wrong with the table.
Hi Gao,
Thank you for a report. Could you please provide me input video files that you used?
Best wishes,
Anna
Hi Anna,
Thank you for your reply.
I have used two videos:
afd_source_1080p_8000kbps.mov: http://pan.baidu.com/s/1dFuiQ5b
ring_source_1080p_10000kbps.mov: http://pan.baidu.com/s/1hrMSN5a
I use ffmpeg to convert them to YUV420p. And because they are too large, I only use parts of them. Below are the comand lines:
ffmpeg -ss 00:00:00 -i afd_source_1080p_8000kbps.mov -t 00:00:42 -s 1920x1080 -y -an -pix_fmt yuv420p afd_1080.yuv
ffmpeg -ss 00:00:00 -i afd_source_1080p_8000kbps.mov -t 00:00:42 -s 1280x720 -y -an -pix_fmt yuv420p afd_720.yuv
ffmpeg -ss 00:00:30 -i ring_source_1080p_10000kbps.mov -t 00:00:18 -s 1920x1080 -y -an -pix_fmt yuv420p ring_1080.yuv
I can't download video from these links because of network error. Could you please compress files and attach to a comment at this topic?
Best wishes,
Anna
The videos are uploaded in the attachment.
Thanks for providing files. What exact PSNR and SSIM did you use: PSNR-Y, PSNR-U, PSNR-V or PSNR-O? Is it average PSNR/SSIM or you measured worst case numbers?
Best wishes,
Anna
I get PSNR(among Y, U and V)/SSIM of each frame, and calculate the average of them.
Hi Anna,
Have you got the results of encoding performances between 4th i7 and 6th i5?
Look forward to your soonest reply. Thanks.
Hi Anna,
It's very interesting from gao c's results. Could you confirm the results?
David
Sorry for delayed reply. I tried to reproduce the problem on i5-6260U (Skylake) and i7-4770K (Haswell), but PSNR and SSIM results were similar or even Skylake produced a little bit better quality. Check that you have the latest drivers and Media SDK/ Media Server Studio versions. Also you can update Samples version from here: https://github.com/Intel-Media-SDK/samples
Best wishes,
Anna
