hi,
I am accessing my Ubuntu from windows10 remotely (as this way describes, https://askubuntu.com/questions/592537/can-i-access-ubuntu-from-windows-remotely ). I have MSS installed. And using SSH terminal, vainfo and samples runs perfectly without problem. That's fine. However problems happens with remote desktop. And I find myself is in a dilemma - unset DISPLAY or export it?
Let me illustrate.
1. Problem begins with CodeBuilder of eclipse failure with error - "Failed to update machine list: Could not load required libraries: please make sure to set the correct path under the Code Builder for OpenCL preference page."
2. So, I went to check "python sys_analyzer_linux.py -v". And got this error, (please note: everything works find with SSH client terminal)
Hardware readiness checks:
[ OK ] Processor name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
[ INFO ] Intel Processor
[ INFO ] Processor brand: Core
[ INFO ] Processor arch: Skylake
OS readiness checks:
[ INFO ] GPU PCI id : 1912
[ INFO ] GPU description: SKL DT GT2
[ OK ] GPU visible to OS
[ INFO ] no nomodeset in GRUB cmdline (good)
[ INFO ] Linux distro : Ubuntu 16.04
[ INFO ] Linux kernel : 4.4.0
[ INFO ] glibc version : 2.23
[ INFO ] Linux distro suitable for Generic install
[ INFO ] gcc version : 20160609 (>=4.8.2 suggested)
Media Server Studio Install:
[ OK ] user in video group
[ OK ] libva.so.1 found
[ ERROR ] libva not loading Intel iHD
[ ERROR ] vainfo not reporting codec entry points
[ INFO ] i915 driver in use by Intel video adapter
[ OK ] /dev/dri/renderD128 connects to Intel i915
Component Smoke Tests:
[ OK ] Media SDK HW API level:1.23
[ OK ] Media SDK SW API level:1.23
[ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK
platform:Experimental OpenCL 2.1 CPU Only Platform GPU OK CPU OK
3. Then I ran "vainfo" (also with remote desktop). Problem shows:
libva info: VA-API version 0.99.0
Xlib: extension "XFree86-DRI" missing on display ":10.0".
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
vaInitialize failed with error code -1 (unknown libva error),exit
4. I noticed environment variable "DISPLAY=:10.0" is set with remote desktop. If unset DISPLAY, vainfo works without problem.
5. But I cannot unset DISPLAY or export "DISPLAY=:0.0". Because, if I unset it, eclipse would fail with X server connection issue:
Failed to connect to Mir: Failed to connect to server socket: No such file or directory
Unable to init server: Could not connect: Connection refused
Eclipse: Cannot open display:
Summary: the dilemma is, I have to keep "DISPLAY=:10.0" to start eclipse; while at the same time I have to disable it to make CodeBuilder work (it seems CodeBuilder depends on vainfo-like va driver access).
P.S. My system info:
Media SDK Client or Media Server Studio version installed: MediaServerStudioEssentials2017R3.tar.gz
Processor Type (required both for Linux & Windows OS): Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Operating System (required both for Linux & Windows OS): Ubuntu 16.04.3 LTS
In addition for Linux OS, please let us know the o/p of uname -r cmd on your system: Linux iot-demo 4.4.0 #2 SMP Tue Oct 17 11:42:45 CST 2017 x86_64 x86_64 x86_64 GNU/Linux (Ubuntu 16.04 original kernel version4.10.0-28. I downgraded it as MSS release required.)
you may also want to try following command lines, on remote access.
$ export DISPLAY=:0.0
$ vainfo
