Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
2970 Discussions
ARC QSV AV1 encoding; should it always output in PTS order?
oviano
I logged this bug in FFmpeg:
https://trac.ffmpeg.org/ticket/10062
To help me better understand whether it's an FFmpeg issue or a QSV/oneVPL issue, I would like to know if when encoding with AV1, with non zero B-Frames (GopRefDist > 1) is it expected that the output of the encode can be DTS order, with PTS jumping back and forward? The above bug report shows what I mean.
It's just that FFmpeg doesn't expect this from AV1, and as a safety-check it sets DTS to PTS somewhere in the processing chain after encoding a frame, which then produces a ton of warnings further on in the chain because the DTS is no longer non-monotonous. The output is also jerky as the frames are clearly out of order/incorrectly stamped.
The developers of Handbrake appear to have come across a similar issue, and someone suggested it's an issue with the ARC driver and a fix will be forthcoming:
https://github.com/HandBrake/HandBrake/issues/4570
Can anyone clarify if that is the case, as I've not seen reference to the issue here.
RemyaP_Intel
Windows driver updates happen on their own schedule and are deliberately not tied to VPL releases. There can be a delay of several weeks between when a fix is merged to the driver/RT repo and when it is available in a public Windows release.
We can usually say in situations like this, just keep watching the downloadcenter for driver version updates. Just to set expectations there is a good chance that the public release won't be available on the downloadcenter before January.
Remya Premdas
RemyaP_Intel
Could you please share the below information to help you:
OS version and processor details
OneVPL version.
Remya Premdas
oviano
Windows 11 Pro 22H2
Intel i7-12700K
OneVPL 2022.2.5 release
So after further research it appears to be a bug in your driver (see below) that you already fixed back in April but haven't yet released. Is there any chance you could release this fix in the next Windows driver release so that we can make full use of the ARC AV1 encoding capabilities? This might avoid the next person like me wasting time trawling the Internet for solutions....only to find it's already been covered, just not yet released
https://github.com/oneapi-src/oneVPL-intel-gpu/issues/206
RemyaP_Intel
Remya Premdas
RemyaP_Intel
We haven't heard back from you. Did we clarify your query? If yes, can we go ahead and close this case?
Remya Premdas
RemyaP_Intel
Thanks for confirming. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
