On my I3770 system, the AUD, SPS, and PPS are missing from the output bit stream. The buffer appears to be padded with leading zeros. On an older Core I5 with HD 3000, the output stream stream is correct. Using the Media SDK R2 2014 with Intel video drivers, 10.18.10.3621 with hardware encode. I can duplicate with the standard sample_encode applications.
Both systems are running Windows 8.1 x64 although the applications are 32 bit. Using VS2010.
Tried switching from the hardware encoder to a software encoder (on the I3770), and the m_mfxSession.Init dies in the debugger.
Any suggestions on how to track these issues?
Thanks for your report. A few more details about the two different machines could help. Could you make sure I've interpreted correctly and fill in the blanks below?
New machine (AUD, SPS, PPS missing)
- Processor: i3770
- Driver version: 10.18.10.3621
- Media SDK Version: Media SDK R2 2014
Old machine (works)
- Processor: ?
- Driver Version: ?
- Media SDK Version: ?
Any chance you could include more details on how to replicate with sample_encode? If you've modified anything, please send the lines changed (or attach the full source if that is easier).
Regards, Jeff
- Processor: i3770
- Windows 8.1 x64
- 16 MB memory
- Dual displays connected to the HD 4000
- 3rd display connected to an NVidia card. Have disabled the NVidia card, no change in behavior.
Old machine (works)
- Processor: I5-2557M
- Driver Version:9.17.10.3347
- Windows 8.1 x64
- 4 MB memory
- Single display (this is a 2011 Macbook Air running with Bootcamp).
No source changes were made to sample_encode. Here are the command line parameters:
h264 -hw -i c:\temp\h264test\h264decodedFrames.yuv -o out.264 -w 1920 -h 1080
Here's the output from SDK analyzer:
New (problematic) machine:
Intel Media SDK System Analyzer (32 bit)
The following versions of Media SDK API are supported by platform/driver:
Version Target Supported Dec Enc
1.0 HW Yes X X
1.0 SW Yes X X
1.1 HW Yes X X
1.1 SW Yes X X
1.3 HW Yes X X
1.3 SW Yes X X
1.4 HW Yes X X
1.4 SW Yes X X
1.5 HW Yes X X
1.5 SW Yes X X
1.6 HW Yes X X
1.6 SW Yes X X
1.7 HW Yes X X
1.7 SW Yes X X
1.8 HW Yes X X
1.8 SW Yes X XGraphics Devices:
Name Version State
Intel(R) HD Graphics 4000 10.18.10.3621 Active
NVIDIA GeForce GTX 650 9.18.13.3221 ActiveSystem info:
CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
OS: Microsoft Windows 8.1 Pro
Arch: 64-bitInstalled Media SDK packages (be patient...processing takes some time):
Intel Media SDK DirectShow* Sample 5.0.337.78585
Intel« Media SDK Video Encoding Sample 5.0.461.91752
Intel« Media SDK 2014 R2 for Clients (x64)Installed Media SDK DirectShow filters:
Installed Intel Media Foundation Transforms:
Intel« Hardware M-JPEG Decoder MFT : {00C69F81-0524-48C0-A353-4DD9D54F9A6E}
Intel« Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}
Old system (working):
The following versions of Media SDK API are supported by platform/driver:Version Target Supported Dec Enc
1.0 HW Yes X X
1.0 SW No
1.1 HW Yes X X
1.1 SW No
1.3 HW Yes X X
1.3 SW No
1.4 HW Yes X X
1.4 SW No
1.5 HW No
1.5 SW No
1.6 HW No
1.6 SW No
1.7 HW No
1.7 SW No
1.8 HW No
1.8 SW NoGraphics Devices:
Name Version State
Intel(R) HD Graphics 3000 9.17.10.3347 ActiveSystem info:
CPU: Intel(R) Core(TM) i5-2557M CPU @ 1.70GHz
471}
Tips:
- SW target does not work: make sure Media SDK DLL (e.g. libmfxsw64.dll)
is located in your executable path or in system path
I may have found the problem. According to the debugger the mfxSession.Init, loaded the library from here:
loaded 'C:\Program Files\Intel\Media SDK\libmfxhw32.dll',
However, there's also a copy of the same dll in the 2014 client R2 folder with a slightly older date. After renaming the Intel\Media SDK folder to something else, our software loads the library from:
Loaded 'C:\Program Files\Intel\Media SDK 2014 R2 for Clients\bin\win32\libmfxsw32.dll'
And now I get the AUD, SPS, PPS. However the QuickSync is defaulting to a software implementation instead of hardware.
THe is the contents of 2014 R2 bin folders:
Directory of C:\Program Files\Intel\Media SDK 2014 R2 for Clients\bin\win32
07/14/2014 06:16 PM <DIR> .
07/14/2014 06:16 PM <DIR> ..
04/28/2014 04:28 PM 16,493,288 libmfxsw32.dll
1 File(s) 16,493,288 bytesDirectory of C:\Program Files\Intel\Media SDK 2014 R2 for Clients\bin\x64
04/28/2014 04:29 PM 20,668,648 libmfxsw64.dll
1 File(s) 20,668,648 bytesTotal Files Listed:
2 File(s) 37,161,936 bytes
And here are the contents of the Media SDK folder. Where did these files come from?
07/26/2014 04:51 PM <DIR> .
07/26/2014 04:51 PM <DIR> ..
05/21/2014 12:33 AM 993 cpa_32.vp
05/21/2014 12:33 AM 993 cpa_64.vp
12/21/2013 04:02 AM 846,855 c_32.cpa
12/21/2013 04:02 AM 1,519,616 c_64.cpa
05/21/2014 12:33 AM 21,523 dev_32.vp
05/21/2014 12:33 AM 21,523 dev_64.vp
05/21/2014 12:33 AM 24,661 he_32.vp
05/21/2014 12:33 AM 5,637 he_64.vp
05/21/2014 12:33 AM 17,542,888 libmfxhw32.dll
05/21/2014 12:33 AM 21,882,088 libmfxhw64.dll
05/21/2014 12:33 AM 626,408 mfxplugin32_hw.dll
05/21/2014 12:33 AM 721,128 mfxplugin64_hw.dll
05/21/2014 12:33 AM 716,800 mfx_mft_h264ve_32.dll
05/21/2014 12:33 AM 889,856 mfx_mft_h264ve_64.dll
05/21/2014 12:33 AM 641,024 mfx_mft_mjpgvd_32.dll
05/21/2014 12:33 AM 792,576 mfx_mft_mjpgvd_64.dll
05/21/2014 12:33 AM 22,541 mj_32.vp
05/21/2014 12:33 AM 5,445 mj_64.vp
18 File(s) 46,282,555 bytes
OK, the problem was never really fixed. Turns out when I deleted the "c:\program files\intel\media sdk" folder, it default to the software driver. I've since deinstalled and re-installed both the intel video driver and the media sdk 2014 R2, and now I'm back to getting encoding output without AUD, SPS, and PPS with an unmodified version of sample_encode.
What's next? Below is the output from the Intel Media SDK:
Intel Media SDK System Analyzer (32 bit) The following versions of Media SDK API are supported by platform/driver: Version Target Supported Dec Enc 1.0 HW Yes X X 1.0 SW Yes X X 1.1 HW Yes X X 1.1 SW Yes X X 1.3 HW Yes X X 1.3 SW Yes X X 1.4 HW Yes X X 1.4 SW Yes X X 1.5 HW Yes X X 1.5 SW Yes X X 1.6 HW Yes X X 1.6 SW Yes X X 1.7 HW Yes X X 1.7 SW Yes X X 1.8 HW Yes X X 1.8 SW Yes X X Graphics Devices: Name Version State Intel(R) HD Graphics 4000 10.18.10.3621 Active NVIDIA GeForce GTX 650 9.18.13.3221 Active System info: CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz OS: Microsoft Windows 8.1 Pro Arch: 64-bit
The 'C:\Program Files\Intel\Media SDK\libmfxhw32.dll' was the proper library to hardware to load and was installed as part of your Intel HD 4000 graphics drivers.
The issue you describe with AUD,SPS,PPS is something that could occur if the platform BIOS is not fully supporting your CPU. Could you please run "DXDIAG" on your platform, select "Save All Information", and provide us the report?
Do you know if the motherboard and BIOS you are using was provided at the same time that the Intel(R) Core(TM) i7-3770 was placed in system, or was this platforms CPU upgraded from a 2nd Generation CPU?
Any information about your platforms BIOS provider would be useful. THANKS
Hi Tony, thanks for the quick response.
Here's the BIOS information per CPU-Z:
Here's a list of BIOS upgrades for this motherboard: http://www.gigabyte.com/products/product-page.aspx?pid=3855#bios
I'm running version F10.
DMI BIOS
vendor Award Software International Inc. version F10 <<< THis version should support Ivy Bridge CPUs. date 02/23/2012 ROM size 4096 KB DMI System Information manufacturer Gigabyte Technology Co. Ltd. product Z68MA-D2H-B3 version unknown serial unknown UUID {00000000-0000-0000-0000-50E54934EAB8} SKU unknown family unknown DMI Baseboard vendor Gigabyte Technology Co. Ltd. model Z68MA-D2H-B3 revision x.x serial unknown
DxDiag information attached.
Thanks, Dan
