Hi
Not sure if I am doing something wrong, but on Ubuntu 14.04, with i7-4760HQ, and 3.8 kernel it seems that I can't decode AVC streams, encoded via sample_encode_drm, to decode at 60 fps, e.g.:
time sample_encode_drm h264 -i ~/Videos/BasketballDrive_1920x1080_50.yuv -o ~/Videos/BasketballDrive_1920x1080_50_60.h264 -w 1920 -h 1080 -hw -b 20000 -u quality -f 60
libva info: VA-API version 0.34. 0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Intel(R) Media SDK Encoding Sample Version 5.0.1603344.93446
Input file format YUV420
Output video AVC
Source picture:
Resolution 1920x1088
Crop X,Y,W,H 0,0,1920,1080
Destination picture:
Frame rate 60.00
Bit rate(Kbps) 20000
Target usage quality
Memory type system
Media SDK impl hw
Media SDK version 1.10
Processing started
Frame number: 501
Processing finished
real 0m7.255s
user 0m2.228s
sys 0m0.784s
Decode:
time sample_decode_drm h264 -o ~/Videos/BasketballDrive_1920x1080_50_60_rec.yuv -i ~/Videos/BasketballDrive_1920x1080_50_60.h264 -hw
libva info: VA-API version 0.34.0
Intel(R) Media SDK Decoding Sample Version 5.0.1603344.93446
Input video AVC
Output format YUV420
Crop X,Y,W,H 0,0,0,0
Frame rate 60.00
Memory type system
MediaSDK impl hw
MediaSDK version 1.10
Decoding started
Frame number: 501, fps: 35.994, fread_fps: 0.000, fwrite_fps: 36.440
Decoding finished
real 0m13.931s
user 0m13.408s
sys 0m1.160s
Setting "-u" to "balanced" and decreasing the bit rate to 5 Mbps, did not change decoders fps rate. Is this to be expected?
Cheers,
Thanks for bringing this to our notice. I am verifying the performance of decoder at 60fps - will get back to you. The decoder performance (decoder fps) on streams encoded at 30fps (frame rate of encoded bitstream) has been in around 200+fps decoder performance.
Ah, I should have mentioned. The decoder fps is being weighed down significantly by the fwrite() operation that is dumping the decoded bytes into a YUV file. If you do not specify the -o parameter for the sample_decode_drm, you should see the pure decoder performance.
My experiment: big_buck_bunny encoded at 60 fps, resolution 1080p:
With file write enabled (-o parameter specified): fps: 27.84, fread_fps: 0.0000, fwrite_fps: 28.341
Without file write (remove -o parameter): fps: 189.647
Hope this helps.
Thank you for the clarification. Indeed, decoding a 4k p60 stream gives the following impressive result:
~# time sample_decode_drm h264 -i ~/Videos/Cycle_noFadeIn_3840x2160.h264 -hw
Input video AVC
Resolution 3840x2160
Frame rate 60.00
Memory type system
MediaSDK impl hw
Decoding started
Frame number: 950, fps: 74.584, fread_fps: 0.000, fwrite_fps: 0.000
Decoding finished
real 0m12.767s
user 0m4.824s
sys 0m0.424s
Cheers,
Very glad you are happy with the performance! Thanks.
