Actual bitrate in sample_encode
ramya_s_
I read through the doc for mfxVideoParam and mfxInfoMFX and did not find a field for the actual bitrate achieved by the encoder. The target bitrate printed is same as the input bitrate. Is the actual bitrate derivable from any other parameters that is available to the user through the API ? I am using a proffessional version of intel media server studio.
Harshdeep_B_Intel
Hi Ramya,
Media SDK includes few common bitrate control methods (BRC) methods, where constant bitrate (CBR) mode is a default method shown with sample. In MSDK API you can control the bit rate by selecting the BRC mode suitable for your application. From mediaSDK manual in  mfxInfoMFX structure, you can set RateControlMethod parameter to achieve this. Here is link to article which explains different BRC modes available:https://software.intel.com/en-us/articles/common-bitrate-control-methods-in-intel-media-sdk. Hope this is the information you are looking for.
Sravanthi_K_Intel
Hi Ramya, If you want to find out the finally achieved bitrate by the encoder, you can use tools such as MediaInfo, Elecard, or even Intel(R) Video Pro Analyzer to find per-frame bitrate achieved. If you want the overall file bitrate, then use the filesize, the length of the stream to compute the bitrate (Mbps).
ramya_s_
Hi harsha, thanks for the link.
Hi sravanthi,
Executed intel mss hevc encoder using sample_encode.exe on skylake using the following commandline
sample_encode.exe h265 -sw -hevc_encoder_plugin 1 -i apple_tree.yuv -w 1920 -h 1080 -f 25 -o spple_tree.hevc -u speed -b 1000 -async 3 -p 2fca99749fdb49aeb121a5b63ef568f7
The input video is of size roughly 1gb with 338 frames and the encoded file size is 1.28 mb. So say the overall file bit rate = encoded file size/no_of_frames * input fps. The value turns out to be 0.09 mbps whereas the input bitrate is 1 mbps. I notice that the achieved bitrate is off the desired bitrate by almost 1/10th for this particular case.
Do spot any inconsistencies if any. Importantly, is there any command line option that I can pass to sample_encode.exe to achieve the desired bitrate ?
Alexey_F_Intel
you have lost a multiplyer by 8, so got MByte/s not MBit/s.
338 frames with 25 fps framerate, it is 13.5 sec. with encoded file size = 1.28MB, you have (1.28 *8)Mbit = 10.24Mbit/13.5 sec = 0.76Mbps
To achieve exact encoded bitrate as desired you Constant Bitrate Control - CBR, it shal have least deviation from the desired target.
