Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
Adaptive B frame
Sheth__Dhrumil
System Configuration
Windows 7 64 bit, Intel I7 processor
used sample - Intel Media Samples 6.0.0.68
I am working on low bitrate H264 aprox 2000 - 2500 kbps. I am using Constant bitrate control mode. I have set 7 as a Target Usage. My h264 output Quality is good.
->My problem is when in Input scene change occur, in output I found pixelation. To remove that I need to add Adaptive B or P frame. But when I tried to set this parameter in option 2 video parameter INTEL SDK Stops giving the output.
->Is there any special technique to use adaptive B frame. I have set B pyramid ON in coding option 2, and used ref frames = 3.
If possible please help me.
Thank you
Dhrumil Sheth
