Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2964 Discussions
Add dar and sar to sample_multi_transcode and sample_encode
Celio_A_
Dear Intel Developers
Its possible to add to sample_multi_transcode and sample_encode par (pixel aspect ratio) and sar (sample aspect ratio)?
For example if i want to encode a SD Asset like 720x480 resolution in 4:3 i add sar 10:11
I bought an intel i5 7500 and wan't to encode to hevc my old home made movies to save hdd space
Currently i can't encode 4:3 without resizing to 720x540, i wan't encode original resolution and original aspect ratio
Stav_S_Intel
Hi  Celio.
Not sure i understand what you are trying to do- to add to the multi transcode sample what?
You can use the samples and add code using MSDK- but at the end the sample is meant for learning- so once you figure out how to use it you may want to change a lot of it to match what you are trying to do.
If i didn't understand, please share more details.
Stav
