Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
Add dar and sar to sample_multi_transcode and sample_encode
Celio_A_
Dear Intel Developers
Its possible to add to sample_multi_transcode and sample_encode par (pixel aspect ratio) and sar (sample aspect ratio)?
For example if i want to encode a SD Asset like 720x480 resolution in 4:3 i add sar 10:11
I bought an intel i5 7500 and wan't to encode to hevc my old home made movies to save hdd space
Currently i can't encode 4:3 without resizing to 720x540, i wan't encode original resolution and original aspect ratio
Stav_S_Intel
Hi  Celio.
Not sure i understand what you are trying to do- to add to the multi transcode sample what?
You can use the samples and add code using MSDK- but at the end the sample is meant for learning- so once you figure out how to use it you may want to change a lot of it to match what you are trying to do.
If i didn't understand, please share more details.
Stav
