Application to play a file decoded by Intel Media SDK
Sam1
Are there any applications that can take a H.264 stream, decode it using Intel Media SDK and play that decoded file (.yuv file that has frames). The OS is Ubuntu 16.04
Jiandong_Z_Intel
Hi There,
I think you may want to try MSDK sample_decode, with -r parameter can render framework to display.
You can download MSDK sample from: https://software.intel.com/en-us/intel-media-server-studio-support/code-samples
Zachary
