Arc (DG2) missing QSV MPEG2 encoder?
r00tb33r
I upgraded my development system from DG1 to Arc (DG2) and now the MPEG2 encoder is not working.
I checked OneVPL documentation to check for Arc feature list, it links the following tables:
https://www.intel.com/content/www/us/en/develop/documentation/media-capabilities-of-intel-hardware/top.html
https://www.intel.com/content/www/us/en/develop/documentation/media-capabilities-of-intel-hardware/top.html#media-capabilities-supported-by-intel-hardware_codecs-encode-support-for-intel-discrete-graphics
So it still just has DG1 in the table and its not updated for Arc.
Can you confirm that MPEG2 encoder is present on Arc?
Rahila_T_Intel
Hi.
Thanks for posting in Intel communities.
Please be informed that currently oneVPL doesn't support Arc(DG2) hardware. The documentation will be updated once the support is added.
Regarding MPEG2 encoding support, we will check with the concerned team and let you know.
Hope this addresses your queries. If so, kindly click the “Accept as Solution” button to indicate that your issue is resolved. This will also help others with a similar issue.
r00tb33r
Rahila_T_Intel
Could you please try to upgrade to the latest ARC driver.  31.0.101.3959 is the latest beta driver for Intel® Arc™ A-Series Graphics.
According to the media-driver table, only MPEG2 decode is supported on DG2.
Please refer to the media-driver table, to find out the codecs supported on DG2: https://github.com/intel/media-driver#components-and-features
r00tb33r
Rahila_T_Intel
Could you please confirm whether your query is clarified?
Please let us know if we can go ahead and close this case?
Rahila_T_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
