Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
Are multiple concurrent instances of sample_encode_drm supported?
Jiline__Mikhail
We are trying to run several sample_encode_drm at the same time to encode multiple streams. However, the second instance fails in libva initialization. Are multiple concurrent instances of sample_encode_drm supported on linux?
Misha
Jeffrey_M_Intel1
Yes, multiple concurrent instances of all Media SDK pipelines should be supported.  However, I am also seeing a bug with the current release limiting to 1 instance.  I'll investigate and get back to you.
Jeffrey_M_Intel1
Are you able to encode multiple instances as root?  This helped on the system where I am investigating. It isn't a full solution, but it could be an important clue.
Jiline__Mikhail
Hi Jeffrey,
Thanks for fast reply. Definetely being the root changes things! But we still were not able to find a proper way to run it...
Running as root:
sudo /opt/intel/mediasdk/samples/_bin/x64/sample_encode_drm h264 -hw
-nv12 -vaapi -w 1920 -h 1080 -i /epiphan/shutterstock_v2844682_x5.nv12
-o shutterstock_v2844682_x5.h264 -u quality
libva info: VA-API version 0.34.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Intel(R) Media SDK Encoding Sample Version 4.0.1602354.61523
Input file format NV12
Output video AVC
Source picture:
Resolution 1920x1088
Crop X,Y,W,H 0,0,1920,1080
Destination picture:
Frame rate 30.00
Bit rate(Kbps) 5009
Target usage quality
Memory type d3d
Media SDK impl hw
Media SDK version 1.6
Processing started
Output video AVC
Source picture:
Frame rate 30.00
Bit rate(Kbps) 5009
Memory type d3d
Media SDK impl hw
Return on error: error code -17,
/msdk/validation/linux_val/validation/ww29.5_Linux-HSW_vc54_Ubuntu_12.04/samples/sample_encode/src/pipeline_encode.cpp
1242
ERROR: Hardware device was lost or returned an unexpected error. Recovering...
No error when running as a normal user (in group video)
Misha.
Jeffrey_M_Intel1
Media SDK for Linux Servers is very sensitive to installation. While I have not seen this particular behavior before, strange behavior like this can often be traced back to not having a supported configuration set up.  Please check your configuration agains the procedure here: http://software.intel.com/en-us/forums/topic/472852
This may not help the problem of multiple sessions needing root, but carefully following this procedure may help with the error you've most recently described.
A more complete installation guide is being included in a future release.
Thanks!
