3027 Discussions
[BRX/APL] Very Slow frame fetch from the GPU to CPU #1191
Kevin_T_Tang
J4125(Gen9) has low performance for sample_decode:
sample_decode h264 -i 1080p.264 -o /dev/null -rgb4
On the Windows side, with 2021R1, it is 30fps
On the Linux side, only 15fps, any ideas to improve the performance?
Related links:
https://github.com/intel/media-driver/issues/1191
https://github.com/intel/media-driver/pull/646
AlekhyaV_Intel
Thank you for posting in Intel Communities. We are working on this internally. Could you please let us know your OS details?
Alekhya
AlekhyaV_Intel
Hi Kevin,
We tried reproducing your issue on a Coffee Lake machine but couldn't reproduce your issue. IoT processors, e.g., Gemini Lake Processor, have relatively simple/slow CPU cache hierarchies, so I/O will be slow. That's why the problem isn’t apparent on Coffee Lake Processor.
To see the true performance of the HW, please use the following command line:
(Remove the pixel format conversion options and output options)
You may need to add flags to keep the frames in video memory like '-vaapi' for Linux.
Performance should increase with multiple simultaneous decodes.
If this resolves your issue, please accept this as a solution. This might help others with similar issue. Thanks.
Alekhya
AlekhyaV_Intel
Is your issue resolved? Could you please give us an update regarding this issue?
Alekhya
AlekhyaV_Intel
We assume that your issue is resolved. If you need any further assistance, please post a new question as this query will no longer be monitored by Intel.
Alekhya
