Blending two NV12 frames.
Hamza_U_1
Hi All,
I'm trying to blend two nv12 files. I'm Using sample code from https://software.intel.com/en-us/forums/intel-media-sdk/topic/536779 post.
I'm using one 1920x1080 yuv file and another one is 720x576. Blending of Luma appears fine, where as colors are scattered as 4 quadrants.
Attaching modified code as well.
Harshdeep_B_Intel
Hi Hamza,
Can you please share more details about your system configuration like OS, hardware etc. Also, can you verify and confirm if latest version of MediaSDK/Media Server studio installed on your machine?
Hamza_U_1
Hi Harsh,
I'm using E3-1245 v5, with centos-release-7-2.1511.el7 64-bit.
Yes i'm running latest version of MediaSDK and I'm able to blend the same two files using MediaSamples_Linux_2016. Did you have a chance to run the attached code in your set-up ?
Harshdeep_B_Intel
Hi Hamza,
We have a known bug on this issue and currently under investigation by our dev team. Will update soon once I have any information. Thank you for reporting this bug.
Hamza_U_1
Hi Harsh,
There was an issue in utils that i was using. It was reading nv12 files as yv12. Blending is fine after fixing that.
Harshdeep_B_Intel
Hi Hamza,
Thanks for the update. Yes, NV12 input is expected. Glad, you were able to resolve this issue. Let's close this thread and please start a new thread for further questions.
