Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Broken output file
kim__taehan
I am developing screen capture App using QSV and ffmpeg
My app create MP4(h.264) file well,
but when I play Mp4 file..the result is bad .. like below
Did I do something wrong or setup up Encoding parameters , VPP parameters badly?
Anyone help me please..
Here is Result of System Analyzer
Intel(R) Media Server Studio 2016 R2 - System Analyzer (64-bit)
The following versions of Media SDK API are supported by platform/driver
[opportunistic detection of MSDK API > 1.19]:
        Version Target  Supported       Dec     Enc
        1.0     HW      Yes             X       X
        1.0     SW      Yes             X       X
        1.1     HW      Yes             X       X
        1.1     SW      Yes             X       X
        1.2     HW      Yes             X       X
        1.2     SW      Yes             X       X
        1.3     HW      Yes             X       X
        1.3     SW      Yes             X       X
        1.4     HW      Yes             X       X
        1.4     SW      Yes             X       X
        1.5     HW      Yes             X       X
        1.5     SW      Yes             X       X
        1.6     HW      Yes             X       X
        1.6     SW      Yes             X       X
        1.7     HW      Yes             X       X
        1.7     SW      Yes             X       X
        1.8     HW      Yes             X       X
        1.8     SW      Yes             X       X
        1.9     HW      Yes             X       X
        1.9     SW      Yes             X       X
        1.10    HW      Yes             X       X
        1.10    SW      Yes             X       X
        1.11    HW      Yes             X       X
        1.11    SW      Yes             X       X
        1.12    HW      Yes             X       X
        1.12    SW      Yes             X       X
        1.13    HW      Yes             X       X
        1.13    SW      Yes             X       X
        1.14    HW      Yes             X       X
        1.14    SW      Yes             X       X
        1.15    HW      Yes             X       X
        1.15    SW      Yes             X       X
        1.16    HW      Yes             X       X
        1.16    SW      Yes             X       X
        1.17    HW      Yes             X       X
        1.17    SW      Yes             X       X
        1.18    HW      Yes             X       X
        1.18    SW      Yes             X       X
        1.19    HW      Yes             X       X
        1.19    SW      Yes             X       X
Graphics Devices:
        Name                                         Version             State
        Intel(R) HD Graphics 530                     20.19.15.4483       Active
        NVIDIA Quadro M2000M                         21.21.13.7699       Active
System info:
        CPU:    Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz
        OS:     Microsoft Windows 10 Pro
        Arch:   64-bit
Installed Media SDK packages (be patient...processing takes some time):
        Intel(R) Media SDK 2016 R2
Installed Media SDK DirectShow filters:
Installed Intel Media Foundation Transforms:
        Intel(R) Hardware M-JPEG Decoder MFT : {00C69F81-0524-48C0-A353-4DD9D54F9A6E}
        Intel(R) Hardware VP8 Sync Decoder MFT : {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}
        Intel(R) Hardware VP8 Decoder MFT : {6D856398-834E-4A89-8EE5-071BB3F58BE4}
        Intel(R) Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}
        Intel(R) Hardware H265 Encoder MFT : {BC10864D-2B34-408F-912A-102B1B867B6C}
Analysis complete... [press ENTER]
Ramashankar
New Contributor III
Hi Kim,
How can i fix this problem on 6th Intel CPU fundamentally??
I am not sure but I feel its ok to have different pitch value on different hardware/driver. We just need to be careful while copying frames between buffers using pitch value.
Let me know how you are copying raw frames into vpp buffer. Are you copying complete frame in one go (like doing memcpy of full buffer in a single call) or are you copying frames row by row (one row in a single memcpy call)?
If you are doing single memcpy of complete buffer in one call then it is wrong. Do row by row memcpy using source and destination pitch.
Ramashankar
New Contributor III
Hi Kim,
By seeing your output image, it looks like you are using incorrect width of capture frames.
What is your screen resolution? Make sure you are using pitch value correctly when processing raw frame buffer for encoding.
kim__taehan
Thank you for replay Ramashankar.
I am using 1920 x 1080 and wondering how can I fix pitch value?
kim__taehan
In addition,
When I debug , Figured out that row pitch of real image(raw frame) is 7680 (1920 * 4)
but, pmfxSurfacesVPPIn[nVPPSurfIdx]->Data.Pitch value is "7808"
Is it skylake driver bug?
Ramashankar
New Contributor III
Hi Kim,
It may or may not be a bug, but one thing for sure is that you need to copy your raw frame in vpp surface by using source pitch as 7680 and destination pitch as 7808, that is after copying 7680 bytes, move your source buffer by 7680 and destination buffer by 7808. It should solve your issue.
kim__taehan
Thank you Ramashankar!
I debugged with same source  on my LaptopPC(4th intel CPU)
the result is that row pitch of real image(raw frame) is 7680
and pmfxSurfacesVPPIn[nVPPSurfIdx]->Data.Pitch value is 7680 as  well.
output mp4 file is working well!
what is diffrence between 4th Intel CPU and 6th Intel CPU???
As you said pitch value may be a  cause..
P.S Actually I get pitch value by using IDirect3DSurface9::LockRect method.. it returns pitch value "7808"
Ramashankar
New Contributor III
Hi Kim,
kim__taehan
Hi Ramashankar,
I found that I am not using pitch value But, just using frame copy like..
"memcpy(pSurface->Data.B, fSource, h * w * 4)"
this function is called just before encoding..
and I checked raw data after memcpy()
for example..
memcpy(pSurface->Data.B, fSource, h * w * 4);
BYTE* buf = new BYTE[1920 * 4 * 1080];
int c = 0;
for (int i = 0; i < 1920; i++)
      for (int j = 0; j < 1080; j++)
            buf[c + 0] = (BYTE)pSurface->Data.B[c + 0];
            buf[c + 1] = (BYTE)pSurface->Data.B[c + 1];
            buf[c + 2] = (BYTE)pSurface->Data.B[c + 2];
            buf[c + 3] = (BYTE)pSurface->Data.B[c + 3];
            c += 4;
SaveBitmapToFile((BYTE*)buf,
1920,
1080,
32,
0,
L"C:\\MyFolder\\bluesquare.bmp");
delete[] buf;
bmp file is fine...
after that it called runFrameVPPAsync method...and I can't debug anymore..because it's library method..
Thx for your reply
kim__taehan
Hi Ramashankar,
Yes..you are right
I have to data copy row by row
Finally, I resolved this problem !!
Thank you very much and Happy new year!
Ramashankar
New Contributor III
Hi Kim,
Great to hear that your issue is resolved.
As a general practice, always do raw frame buffer copy row by row using source and destination pitch value. It will work on all hardware/devices/driver, inspite of any pitch value.
Happy New Year to you too :)
