Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Bug in IMSDK samples
OTorg
New Contributor III
line at current sample_encode\src\pipeline_encode.cpp:
[plain]initPar.Implementation = (initPar.Implementation & !MFX_IMPL_HARDWARE_ANY) | MFX_IMPL_HARDWARE;[/plain]
should be replaced by:
[plain]initPar.Implementation = (initPar.Implementation & ~MFX_IMPL_HARDWARE_ANY) | MFX_IMPL_HARDWARE;[/plain]
(binary NOT confused with logical NOT)
Mark_L_Intel1
Thanks, I will post a bug to the dev team.
Mark
Mark_L_Intel1
Hi dj_alek,
Thanks for checking the sample code. Can you also confirm if the sample can run correctly after your suggested code change? I will report the bug once you confirmed.
Mark
OTorg
New Contributor III
Yes, the sample runs correctly.
PS:
This is such an obvious mistake that it doesn't even need to be checked:)
Mark_L_Intel1
Mark
