Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Bug in the H.264 Hardware Decoder
charliegood
There seems to be a bug in the H.264 hardware decoder.
The sample file is here:
http://www.wowzamedia.com/_h264/wowzamedia.h264
When I run this command I get good looking YUV output:
sample_decode.exe h264 -i wowzamedia.h264 -o wowzamedia_sf.yuv
When I run this command I get bad looking YUV output (blocky artifacts in many frames):
sample_decode.exe -hw h264 -i wowzamedia.h264 -o wowzamedia_hw.yuv
Here are the environment details:
Intel Media SDK: 2.0.12.24071
Hardware:
Processor: Sandy Bridge, 2600K
Driver version: Intel Corporation, 1/7/2011, 8.15.10.2279
Motherboard: ASUS, P8H67-MEVO
The source file was encoded using x264 with this command line:
ffmpeg -i wowzamedia.ts -strict experimental -pass 1 -s 1280x720 -y -an -vcodec libx264 -vpre default -vpre hq -vpre main -g 150 -b 3000k -bt 3000k -threads 64 wowzamedia.mov
ffmpeg -i wowzamedia.ts -strict experimental -pass 2 -s 1280x720 -y -acodec aac -ab 128k -ac 2 -ar 48000 -vcodec libx264 -vpre default -vpre hq -vpre main -g 150 -b 3000k -bt 3000k -threads 64 wowzamedia.mov
Let me know if you need any further information.
Charlie
charliegood
You guys rock!
Thanks a ton,
Charlie Good
Wowza Media Systems
Eric_S_Intel
Sorry for the delay Charile, We will look into this.
-Eric
IDZ_A_Intel
Hi Charlie,
we have reproduced the issue. Investigation is ongoing, we'll get back to as soon as we know more.
In the meantime, if needed, to circumvent the issue please try different ffmpeg encoder options.
I experimented with ffmpeg (0.5.7) using similar options as you referred to in your report but was not able to produce a H264 stream resulting HW decode issues.
Petter
charliegood
BTW, the version of FFmpeg that I used to create this file is:
ffmpeg-r26400
It is from this site:
http://ffmpeg.arrozcru.org/autobuilds/
Charlie
IDZ_A_Intel
Hi Charlie,
The issue has been resolved in Media SDK HW encode path. We expect the fix to be part of the 15.22 production build of the platform Graphics Driver (including Intel Media SDK HW implementation) in ww14 (end of March).
Thanks for helping us improve Intel Media SDK/Intel Quick Sync Technology.
Let me know if you have any questions.
Petter
charliegood
You guys rock!
Thanks a ton,
Charlie Good
Wowza Media Systems
