How to build a oneVPL application? Like a sample blank application that I can then edit.
Hi there,
Thanks for trying our product and provide valuable feedback.
We are at the Beta stage, and apologized for the lack of documentation. The best method to create an VPL application is to use our sample code. For decoding application, you can use 01_decode_simple in the following URL:
https://github.com/intel/BaseKit-code-samples/tree/master/VideoProcessingLibrary/01_decode_simple
You can also check oneAPI spec for the API descriptions:
https://spec.oneapi.com/versions/0.7/elements/oneVPL/source/index.html
Let me know if this helps.
Mark
Hi there,
Mark
