CPU load and privete bytes of Quick Sync softwae is ever increasing.
Suzuki__Hidekazu
Hello.
I have 2 issues on H.264 decoding software using Intel media SDK - Quick Sync hardware decoding.
Issue 1: CPU load of the software is ever-increasing. It reaches to 100% in 5 or 10 hours then keep 100%. We checked using process explorer and found there is many MFXVideoVPP_GetVPPStat threads (150 threads) and CPU load of each thread is ever increasing.
Issue 2: Private bytes of the program is ever-increasing. It seems memory leak.
My environment:
Windows10 Enterprise 1607
16GB memory
SkyLake Xeon E3-1275 v5 (I have same issues on KabyLake Xeon E3-1275 v6)
Driver version on device manager: 22.20.16.4815 (Old version driver didn't have these 2 issues but it had more critical issue so I cannot use the old driver.)
I need solution of these 2 issues ASAP. Kindly give me any advice.
PrivateBytesOfQuickSyncSoftware.pngCPULoadOfQuickSyncSoftware.pngTotalCPULoad.pngThread2.png
dedisse__daniel
I have exactly the same problem.
Doing H264 decoding, after some time the CPU increase with a lot of MFXVideoVPP_GetVPPStat threads
My environement :  CPU I5 7260U + Iris 650. Driver 23.20.16.4877
The same software works fine with : CPU I5 6300U + HD520. Driver 21.20.16.4550
This is really a big big issue.
HELP NEEDED FROM INTEL DEVELOPERS;
Beese__Erin
I am having this issue when using software decoding. Are there any updates?
Erin
Mark_L_Intel1
Hi Suziki San,
Sorry for the late response, do you have a reproducer?
We might have some issue with clean up the used frame buffer which causes the memory management issue. Could you double check if your issue are the same as following posts:
https://software.intel.com/en-us/node/753665
https://software.intel.com/en-us/forums/media/topic/681913
Mark
