CPU upgrade issue
lambert__olivier
I've upgraded an old I7 4770K system with a I7 6700 and i got a issue when encoding video using Media SDK
The image resolution is 512x512 - 8bits encoded from YUV in AVC file.
Tried : update media SDK (2013 -> 2017)
update drivers
changing CPU (i7 7700)
How could i correct this?
Thank you.
Anna_B_Intel
Hi Oliver,
I can't open the image you attached. Please attach it to the topic directly.
Are you using Windows? Could you please provide exact driver number?
Best wishes,
Anna
lambert__olivier
Dear Anna,
I'm using Windows 7 pro 64 bits, the driver version is : 15.45.23.4860
Here is the problem illustration :
Thank you in advance.
Regards.
Anna_B_Intel
Hi Oliver,
Please provide me an input stream and parameters to reproduce the issues with sample_encode.
Best wishes,
Anna
lambert__olivier
Hi Anna,
The input stream setting was  :
m_mfxEncParams.mfx.FrameInfo.FourCC       = MFX_FOURCC_NV12;
m_mfxEncParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
m_mfxEncParams.mfx.FrameInfo.PicStruct    = MFX_PICSTRUCT_PROGRESSIVE;
The example used was sample_videoconf (available in 2014).
The problem is now solved, i used the encode example to upgrade my application.
Thank you for your help. you can consider this issue solved.
Regards.
