Hi Oliver,
I can't open the image you attached. Please attach it to the topic directly.
Are you using Windows? Could you please provide exact driver number?
Best wishes,
Anna
Dear Anna,
I'm using Windows 7 pro 64 bits, the driver version is : 15.45.23.4860
Here is the problem illustration :
Thank you in advance.
Regards.
Hi Oliver,
Please provide me an input stream and parameters to reproduce the issues with sample_encode.
Best wishes,
Anna
Hi Anna,
The input stream setting was :
m_mfxEncParams.mfx.FrameInfo.FourCC = MFX_FOURCC_NV12;
m_mfxEncParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
The example used was sample_videoconf (available in 2014).
The problem is now solved, i used the encode example to upgrade my application.
Thank you for your help. you can consider this issue solved.
Regards.
