Cannot initiate MFXAudioENCODE
elsparro
I can not initiate the encoder from MediaSDK2014AudioPack.
I run on CentOS 7.1, CPU E3-1285L v4
Init function fail with errorcode -3
Any points in the right direction is appriciated.
Best Regards
/elsparro
Here is my test code:
#include <mfxaudio++.h>
#include <mfxaudio.h>
#include <cstdio>
#include <cstring>
int main(int argc, char** argv)
        mfxStatus ret = MFX_ERR_NONE;
        mfxIMPL impl = MFX_IMPL_SOFTWARE | MFX_IMPL_AUDIO;
        mfxVersion ver = { 0, 1 };
        MFXAudioSession session;
        ret = session.Init(impl, &ver);
        if (ret != MFX_ERR_NONE) {
                ::fprintf(stderr, "cannot initiate session, ret: %d\n", ret);
                return -1;
        ret = session.QueryIMPL(&impl);
                ::fprintf(stderr, "cannot query implementation\n");
                return -1;
        ret = session.QueryVersion(&ver);
                ::fprintf(stderr, "cannot query version\n");
                return -1;
        ::fprintf(stderr, "Intel Media SDK Audio Implementation: %d, Version: %d.%d\n",
                  impl, ver.Major, ver.Minor);
        MFXAudioENCODE enc(session);
        mfxAudioParam param;
        ::memset(&param, 0, sizeof(param));
        param.mfx.CodecId = MFX_CODEC_MP3;
        param.mfx.Bitrate = 128000;
        param.mfx.SampleFrequency = 48000;
        param.mfx.NumChannel = 2;
        param.mfx.BitPerSample = 16;
        ret = enc.Query(&param, &param);
                ::fprintf(stderr, "cannot query encoder params, ret: %d\n", ret);
                return -1;
        mfxAudioAllocRequest req;
        ret = enc.QueryIOSize(&param, &req);
                ::fprintf(stderr, "cannot query iosize, ret: %d\n", ret);
                return -1;
        ret = enc.Init(&param);
                ::fprintf(stderr, "cannot initiate encoder, ret: %d\n", ret);
                return -1;
        return 0;
Compiled with: g++ -o audio_session audio_session.cpp -I/opt/intel/mediasdk/include -L/opt/intel/mediasdk/lib/lin_x64 -lmfx -ldl
Jiandong_Z_Intel
Hi There,
MediaSDK2014 is not the most new version.
can you download and install Intel® Media Server Studio 2016 from https://software.intel.com/en-us/intel-media-server-studio/try-buy ?
Let me see if the same issue happened under the most new MSS.
Zachary
elsparro
Nope, still dont work, get the exact same output, error -3 and even the same version 1.8.
I removed all files from the 2014 SDK and installed 2016 evaluation.
I also checked with strace that the right libmfxaudiosw.so was loaded.
Another question, I bought the 2014 audio packs as a standalone package form an intel reseller, is it possible to buy the 2016 audio pack version to work with the 2016 SDK essential?
Best Regards
/elsparro
