Capture screen
kkbee
I want to capture screen and encode by using Sandy bridge.
Which way of capturing screen is best?
Any example?
Vassili_Yakovlev
Hi kkbee,
Screen capturing has no relation to the platform, SandyBridge or Intel MSDK. There are different methods of screen capturing.
You can find a lot of information on internet, for example : http://www.codeproject.com/Articles/5051/Various-methods-for-capturing-the-screen
Vassili
kkbee
Hi Vassili,
Any example about encodeDirect3D data by using intel media sdk.
Thanks for your reply.
Nina_K_Intel
Hi kkbee,
Please check out the sample_encode under Media SDK samples. It has a code path which shows Media SDK Encoder working with Direct3D9 surfaces (follow the path defined by command line option "-d3d").
Nina
kkbee
Hi ,
Does Media SDK support trans file format to mpeg2 ts?
If not , any lib I can use(IPP)?
Petter_L_Intel
Hi kkbee,
Media SDK does not have direct support for media containers such as mpeg2 TS. Intel IPP samples provides one alternative for muxing/demuxing containers. If you'd like to pursue this option please refer to the following white papers:http://software.intel.com/en-us/articles/muxing-with-intel-media-software-development-kit-1/, http://software.intel.com/en-us/articles/demuxing-with-intel-media-sdk/
If this does not fit your needs, there are also many other muxing/demuxing solutions available.
Petter
