I want to capture screen and encode by using Sandy bridge.
Which way of capturing screen is best?
Any example?
Hi kkbee,
Screen capturing has no relation to the platform, SandyBridge or Intel MSDK. There are different methods of screen capturing.
You can find a lot of information on internet, for example : http://www.codeproject.com/Articles/5051/Various-methods-for-capturing-the-screen
Vassili
Vassili
Hi Vassili,
Any example about encodeDirect3D data by using intel media sdk.
Thanks for your reply.
Hi kkbee,
Please check out the sample_encode under Media SDK samples. It has a code path which shows Media SDK Encoder working with Direct3D9 surfaces (follow the path defined by command line option "-d3d").
Nina
Hi ,
Does Media SDK support trans file format to mpeg2 ts?
If not , any lib I can use(IPP)?
Hi kkbee,
Media SDK does not have direct support for media containers such as mpeg2 TS. Intel IPP samples provides one alternative for muxing/demuxing containers. If you'd like to pursue this option please refer to the following white papers:http://software.intel.com/en-us/articles/muxing-with-intel-media-software-development-kit-1/, http://software.intel.com/en-us/articles/demuxing-with-intel-media-sdk/
If this does not fit your needs, there are also many other muxing/demuxing solutions available.
Petter
