I'm trying to run the sample api given for MVC encoder in intel media sdk. I have given input as two files i.e left and right views of a video to get MVC encoded output. But I'm getting a Debug assertion failed message.
I'm using MS visual studio 2010 ultimate to debug and run the code. Pls help.....
This is a known issue (forsample_encode debug build) we will resolve in Media SDK Gold Update 2012, planned for release early April.
Until then please modify the following in your sample_common project.
sample_utils.h: Replace the signature for the Init function in theCSmplYUVReader class from:
virtual mfxStatus Init(const TCHAR *strFileName, const mfxU32 ColorFormat, const mfxU32 numViews, std::vector srcFileBuff);
to
virtual mfxStatus Init(const TCHAR *strFileName, const mfxU32 ColorFormat, const mfxU32 numViews, std::vector &srcFileBuff);
And the same change insample_utils.cpp:
mfxStatus CSmplYUVReader::Init(const TCHAR *strFileName, const mfxU32 ColorFormat, const mfxU32 numViews, std::vector srcFileBuff)
to
mfxStatus CSmplYUVReader::Init(const TCHAR *strFileName, const mfxU32 ColorFormat, const mfxU32 numViews, std::vector &srcFileBuff)
Note that only change applied is using a parameter "&" reference instead of copy call to the function.
Petter
to
to
Petter
