Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
Decode AVPacket by Intel Media SDK
Tien_V_
Starting learning Intel Media SDK with simple_decode_d3d11 sample project. Currently, I'm using ffmpeg library to get H264 stream. My idea is that passing the data from Avpacket to mfxBitstream. So is it possible to follow this way? Trying to fill mfxVideoParam mfx info, vpp info by manually but I'm still getting problem with allocate surfaces for decoder.
Jiandong_Z_Intel
Hi There,
You may want to try following articles -
Reading the most new ffmpeg code may help to find your answer.
Zachary
Tien_V_
Hi Jiandong,
Thanks a lot for your suggestion. I will try following these articles and come back with the result
BRs,
Tien Vo
