Implementing the Video Encoding on Intel Device -Video on Asus Zenfone C ZC451CG.
Recorded a Video from camera From the same Phone and used MediaExtractor to get the media format
MediaFormat inputFormat= extractor.getTrackFormat( trackIndex );
decoder.configure( inputFormat, mOutputSurface.getSurface(), null, 0 );
decoder.start();
02-19 19:21:40.948 186 4611 W MixVBP : Stream was supposed to be SC prefixed, but actually contains a single NAL.
02-19 19:21:40.948 186 4611 W MixVBP : Invalid PPS detected
02-19 19:21:40.948 186 4611 E MixVBP : Slice Header parsing error.
02-19 19:21:40.948 186 4611 W MixVBP : failed to parse the syntax: 12!
02-19 19:21:40.948 186 4611 W OMXVideoDecoder: Decoder returns DECODE_NO_CONFIG.
Seems that Decoder is not able to parse the sps & pps header am printing these headers in the Original Video they are Fine ,am supplying the same format to the MediaCodec.Detailed Log for the same is Provided Below.
Is there anyparamater missing to the codec??
02-19 19:21:40.918 186 4609 D componentbase: OMX.Intel.VideoDecoder.AVC:video_decoder.avc: transition from OMX_StateLoaded to OMX_StateIdle completed
02-19 19:21:40.928 186 4609 D componentbase: OMX.Intel.VideoDecoder.AVC:video_decoder.avc: transition from OMX_StateIdle to OMX_StateExecuting completed
02-19 19:21:40.928 186 4611 I OMXVideoDecoder: Buffer has OMX_BUFFERFLAG_CODECCONFIG flag.
02-19 19:21:40.928 186 4611 I MixVBP : SPS header is parsed.
02-19 19:21:40.928 186 4611 W VideoDecoder: Can't start VA as either SPS or PPS is still not available.
02-19 19:21:40.928 186 4611 I MixVBP : PPS header is parsed.
02-19 19:21:40.928 186 4611 I VideoDecoder: maxDPBSize = 5, num_ref_frame = 1
02-19 19:21:40.928 186 4611 I VideoDecoder: updateFormatInfo: current size: 1920 x 1080, new size: 1920 x 1088
02-19 19:21:40.928 186 4611 I VideoDecoder: Cropping: left = 0, top = 0, right = 0, bottom = 8
02-19 19:21:40.928 186 4611 I VideoDecoder: actualBufferNeeded =17
02-19 19:21:40.928 186 4611 I libva : VA-API version 0.34.0
02-19 19:21:40.928 186 4611 I libva : va_getDriverName() returns 0
02-19 19:21:40.928 186 4611 I libva : Trying to open /system/lib/pvr_drv_video.so
02-19 19:21:40.928 186 4611 I libva : Found init function __vaDriverInit_0_32
02-19 19:21:40.928 186 4611 D pvr_drv_video: hw_get_module returned
02-19 19:21:40.928 186 4611 I libva : va_openDriver() returns 0
02-19 19:21:40.938 2680 4002 D dalvikvm: GC_FOR_ALLOC freed 5920K, 31% free 13202K/19012K, paused 76ms, total 76ms
02-19 19:21:40.948 186 4611 I VideoDecoder: updateFormatInfo: current size: 1920 x 1088, new size: 1920 x 1088
02-19 19:21:40.948 186 4611 I VideoDecoder: Cropping: left = 0, top = 0, right = 0, bottom = 8
02-19 19:21:40.948 186 4611 I VideoDecoder: actualBufferNeeded =17
02-19 19:21:40.948 186 4611 I VideoDecoder: No slice available for decoding.
02-19 19:21:40.948 2680 4002 I dalvikvm-heap: Grow heap (frag case) to 16.958MB for 4147216-byte allocation
02-19 19:21:40.968 2680 2680 D dalvikvm: GC_FOR_ALLOC freed 10K, 26% free 17242K/23064K, paused 23ms, total 23ms
02-19 19:21:40.988 186 4590 E module : found opened module libOMXVideoDecoderAVC.so with name
02-19 19:21:40.988 186 4590 I componentbase: OMX.Intel.VideoDecoder.AVC: set working role video_decoder.avc:
02-19 19:21:40.988 186 4590 I wrs-omxil-core: get handle of component OMX.Intel.VideoDecoder.AVC successfully
02-19 19:21:40.988 186 4590 E OMXVideoDecoder: No more enumeration.
02-19 19:21:40.988 186 4590 E OMXComponentCodecBase: ComponentSetParameter: No handler for index 2130706442
02-19 19:21:40.988 186 4590 E OMXNodeInstance: OMX_SetParameter() failed for StoreMetaDataInBuffers: 0x8000101a
02-19 19:21:40.988 186 4590 I VideoDecoder: Deleting decoder for video/h264
02-19 19:21:40.988 186 4611 W MixVBP : unknown header 0 is parsed.
02-19 19:21:40.988 186 4611 W OMXVideoDecoder: Decoder returns DECODE_NO_CONFIG.
02-19 19:21:40.988 186 4590 I wrs-omxil-core: free handle of component OMX.Intel.VideoDecoder.AVC successfully
02-19 19:21:40.988 186 4590 I SoftOMXPlugin: Created OMXPlugin : OMX.google.h264.decoder
02-19 19:21:40.988 186 4590 I OMXCodec: [OMX.google.h264.decoder] AVC profile = 66 (Baseline), level = 41
02-19 19:21:40.988 186 4590 I OMXCodec: [OMX.google.h264.decoder] video dimensions are 320 x 240
02-19 19:21:40.988 186 4590 I OMXCodec: [OMX.google.h264.decoder] Crop rect is 320 x 240 @ (0, 0)
02-19 19:21:41.008 186 4611 W MixVBP : Invalid PPS detected
02-19 19:21:41.008 186 4611 E MixVBP : Slice Header parsing error.
02-19 19:21:41.008 186 4611 W MixVBP : failed to parse the syntax: 12!
02-19 19:21:41.008 186 4611 W OMXVideoDecoder: Decoder returns DECODE_NO_CONFIG.
private void debugCsd0Csd1(MediaFormat format)
if (format.containsKey("csd-0")) {
ByteBuffer header_sps = format.getByteBuffer("csd-0");
byte[] bt = new byte[header_sps.capacity()];
header_sps.get(bt);
String s = "csd-0: ";
for (byte b : bt) {
s += "0x" + Integer.toHexString(b) + " ";
if(DEBUG_ON)
Log.d(TAG, s);
if (format.containsKey("csd-1")) {
ByteBuffer header_pps = format.getByteBuffer("csd-1");
byte[] bt = new byte[header_pps.capacity()];
header_pps.get(bt);
String s = "csd-1: ";
for (byte b : bt) {
if(DEBUG_ON)
Log.d(TAG, s);
Printing csd Values from the Format
02-20 16:02:24.777: D/VideoResampler(24537): csd-0: 0x0 0x0 0x0 0x1 0x67 0x42 0x40 0x29 0xffffffa6 0xffffff80 0x78 0x2 0x27 0xffffffe5 0x40
02-20 16:02:24.777: D/VideoResampler(24537): csd-1: 0x0 0x0 0x0 0x1 0x28 0xffffffce 0x3c 0xffffff80
Hi Subbu,
Can you please let me know which product are you using implement video encoding on Intel device (Asus Zenfone C ZC451CG)? Please share device OS details? Let me know if you are using Media For Mobile or its samples?
